monza786 Posted July 26, 2011 Share Posted July 26, 2011 hi all i need a polished rad pipe is any one has one lying around or knows of some one (its for a tt if you need that info) sorry bout spelling mistake polished Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 26, 2011 Share Posted July 26, 2011 paul whiffin sells these Link to comment Share on other sites More sharing options...
monza786 Posted July 27, 2011 Author Share Posted July 27, 2011 whats his user name pls Link to comment Share on other sites More sharing options...
Dnk Posted July 27, 2011 Share Posted July 27, 2011 Get a piece of st/st tube or aluminium tube approx 50mm diameter with a 90 degree bend in it, not sure on the lengths either side of the bend but its not hard to measure them, add 2 silicon hose connectors and 4 hose clips job done Have a look here http://www.viperperformance.co.uk they supply the hose and clamps. Check out there prices as the hose is very cheap, under £10 for two 50.8 mm diameter x 76 mm long pieces Or check out http://www.merlinmotorsport.co.uk as they can supply the tube, bend it and swage the ends and supply the hose connectors etc Double check the diameter though as its been a while since i did mine Link to comment Share on other sites More sharing options...
Paul Whiffin Posted August 3, 2011 Share Posted August 3, 2011 Here you go, all in stock http://whifbitzperformancetuning.co.uk/toyota-supra-supra-cooling-parts-radiatorshosesfans-caps-c-42_47_473_474.html Link to comment Share on other sites More sharing options...
monza786 Posted August 5, 2011 Author Share Posted August 5, 2011 Here you go, all in stock http://whifbitzperformancetuning.co.uk/toyota-supra-supra-cooling-parts-radiatorshosesfans-caps-c-42_47_473_474.html Thanks get one ordered Monday hopfully Link to comment Share on other sites More sharing options...
