Engine Misfire
Guest Timbo
Guest Timbo
Hi all,
Guys at the weekend I replaced the stock manifold on my 1996 NA manual Supra, with an OBX stainless steel version which replaced the first Cat, the second cat is still in place and a Kakimoto Cat back system finishes the system. Upon start up the car has developed a horrible missfire, as a result it has caused a lumpy idle and is reduced on power. After getting some help on the forum ( many thanks guys ) resetting the ECU didn't work, I also checked all HT leads and plugs and dizzy cap, I replaced the rotor arm in the distributor, and all too no satisfaction.
I am trying to eliminate the issue and need some help. I am I correct in assuming that if the problem lay with either of the 2 the O2 sensors a dash warning light would come on? as none are on in my case, any idea's
Guest Timbo
The miss is from idle right up to around 4000rpm then it seems to dissapear, driving normally ( under 3000rpm ) the car chuggs along, I don't think it's a fuel delivery issue as it does not splutter at high rpm.
