d-_-b Posted July 25, 2011 Share Posted July 25, 2011 My car hasn't long ago had a full oil change, so the oil which is in the car really isn't that old. I have an oil filter sandwich plate which I want to install but the question is can I fit it without draining out all the oil from the car - more to the point I guess, can I remove the oil filter and not have loads of oil pour out (am aware there will obv be oil in the filter which I would loose) but is it possible to install the plate, refit a new filter then top up the oil? Am aware yes, would have been much better to do the sandwich plate at the same time as the oil change but there was a couple of months between the 2 > Many thanks guys Quote Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 25, 2011 Share Posted July 25, 2011 b;3171823']is it possible to install the plate' date=' refit a new filter then top up the oil?[/quote'] Yes. It really makes no difference whether the sump is full or empty, you'll only lose whats in the filter housing plus whats in the filter obviously. Quote Link to comment Share on other sites More sharing options...
d-_-b Posted July 25, 2011 Author Share Posted July 25, 2011 Yes. It really makes no difference whether the sump is full or empty, you'll only lose whats in the filter housing plus whats in the filter obviously.Great, sounds like the answer I was hoping for :)Thanks for the reply mate Quote Link to comment Share on other sites More sharing options...
d-_-b Posted July 26, 2011 Author Share Posted July 26, 2011 you'll only lose whats in the filter housing Should I be prepared for a lot or a little to come from the housing? Quote Link to comment Share on other sites More sharing options...
marc_p Posted July 26, 2011 Share Posted July 26, 2011 b;3172619']Should I be prepared for a lot or a little to come from the housing? A fair bit, when you unscrew it, expect about a full mugs worth of oil to empty itself out. Quote Link to comment Share on other sites More sharing options...
d-_-b Posted July 26, 2011 Author Share Posted July 26, 2011 A fair bit, when you unscrew it, expect about a full mugs worth of oil to empty itself out.Cheers for that matey, info muchly appreciated Quote Link to comment Share on other sites More sharing options...
