Tein spring settle in period.
Neil-NA
I have recently had some tein s-tech springs fitted along with KYB shock (just under 2 weeks ago), how long does it normally take for them to settle down to the correct ride height, they do seem to be getting lower more or less every day but the front is taking longer than the back, i assume this is because the fronts are stiffer than the rears is this correct?
I bought them off sumo power and they were listed as being for the non turbo and drop the car 32mm front and 20 mm rear
Right just had a quick measure of the height difference between my old stock shocks and these.
Stock -
F351mm
R370mm
Tein+KYB
F350mm
R350mm
Now either the fronts are taking alot longer to settle down due to the higher spring rate or Sumo have sent me the wrong springs and these are ment for a TT
And 2 quick pics - stock suspension
Tein+KYB
If thats the case do i have any comeback as they were purchased around 3 months ago but only fitted 2 weeks ago.
Edited by Neil-NA (see edit history)
Never had this issue with my Eibachs or any other springs, if their too stiff to bounce each corner with
the car stationary take the car for a drive and use a bit of heavy braking to load the suspension.
Obviously in a safe quiet place :)
No decent spring should "settle" at all, even over a period of years. Are you sure the inner suspension arm bushes were not preloaded when fitting these, and the bushes are now twisting or tearing into a relaxed state?
Not too sure Chris i will have to check that, out of interest do you supply springs that would suit the KYB shocks? its all road use, no track days ever and i would like the ride around 20mm lower than stock.
My guess is they are srpings for the TT. THey should have a part number on them to reference
I hope not as that will be the second time Sumo have sent me the wrong parts and they were listed as being for the non turbo, i will have a look at the part numbers tomorrow :(
I can supply some, but would need to get a set made for the N/A, and add them to a batch of TT ones to keep prices sensible. may take a bit of time. Cost would be about £250
Thats a good price Chris, i paid more for the Teins.
not sure if it helps but i have the same springs fitted to my tt have a look in my garage i think my car sits a good bit lower
just fttied tein lowering springs to mine and 100% not happy with them.its dropped hardly nothing so opting for coilovers
Cant say i'm at all happy with them either but i will be asking CW to get me some springs made after suprapod is out the way :(
  • 1 month later...
