Neil-NA Posted July 24, 2011 Share Posted July 24, 2011 I have recently had some tein s-tech springs fitted along with KYB shock (just under 2 weeks ago), how long does it normally take for them to settle down to the correct ride height, they do seem to be getting lower more or less every day but the front is taking longer than the back, i assume this is because the fronts are stiffer than the rears is this correct? I bought them off sumo power and they were listed as being for the non turbo and drop the car 32mm front and 20 mm rear Link to comment Share on other sites More sharing options...
Neil-NA Posted July 25, 2011 Author Share Posted July 25, 2011 (edited) Right just had a quick measure of the height difference between my old stock shocks and these. Stock - F351mm R370mm Tein+KYB F350mm R350mm Now either the fronts are taking alot longer to settle down due to the higher spring rate or Sumo have sent me the wrong springs and these are ment for a TT And 2 quick pics - stock suspension Tein+KYB If thats the case do i have any comeback as they were purchased around 3 months ago but only fitted 2 weeks ago. Edited July 25, 2011 by Neil-NA (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted July 25, 2011 Share Posted July 25, 2011 Never had this issue with my Eibachs or any other springs, if their too stiff to bounce each corner with the car stationary take the car for a drive and use a bit of heavy braking to load the suspension. Obviously in a safe quiet place Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 25, 2011 Share Posted July 25, 2011 No decent spring should "settle" at all, even over a period of years. Are you sure the inner suspension arm bushes were not preloaded when fitting these, and the bushes are now twisting or tearing into a relaxed state? Link to comment Share on other sites More sharing options...
Neil-NA Posted July 25, 2011 Author Share Posted July 25, 2011 No decent spring should "settle" at all, even over a period of years. Are you sure the inner suspension arm bushes were not preloaded when fitting these, and the bushes are now twisting or tearing into a relaxed state? Not too sure Chris i will have to check that, out of interest do you supply springs that would suit the KYB shocks? its all road use, no track days ever and i would like the ride around 20mm lower than stock. Link to comment Share on other sites More sharing options...
Homer Posted July 25, 2011 Share Posted July 25, 2011 My guess is they are srpings for the TT. THey should have a part number on them to reference Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 25, 2011 Share Posted July 25, 2011 I can supply some, but would need to get a set made for the N/A, and add them to a batch of TT ones to keep prices sensible. may take a bit of time. Cost would be about £250 Link to comment Share on other sites More sharing options...
Neil-NA Posted July 25, 2011 Author Share Posted July 25, 2011 My guess is they are srpings for the TT. THey should have a part number on them to reference I hope not as that will be the second time Sumo have sent me the wrong parts and they were listed as being for the non turbo, i will have a look at the part numbers tomorrow I can supply some, but would need to get a set made for the N/A, and add them to a batch of TT ones to keep prices sensible. may take a bit of time. Cost would be about £250 Thats a good price Chris, i paid more for the Teins. Link to comment Share on other sites More sharing options...
nigelboyne Posted July 25, 2011 Share Posted July 25, 2011 I hope not as that will be the second time Sumo have sent me the wrong parts and they were listed as being for the non turbo, i will have a look at the part numbers tomorrow Thats a good price Chris, i paid more for the Teins.not sure if it helps but i have the same springs fitted to my tt have a look in my garage i think my car sits a good bit lower Link to comment Share on other sites More sharing options...
Neil-NA Posted July 26, 2011 Author Share Posted July 26, 2011 Just had a look, cheers mate. Apparently the Tein N/A and TT springs are the same weight @ 10kg front and 4.9kg rear but for the N/A they lower 32mmF and 20mmR where as the TT is 36mmF and 42mmR see here - http://www.tein.co.uk/installation_manual/toyota/JZA80_93-01.html Might just have to wait and get some off Mr Wilson. Link to comment Share on other sites More sharing options...
skippyboyo1 Posted July 26, 2011 Share Posted July 26, 2011 just fttied tein lowering springs to mine and 100% not happy with them.its dropped hardly nothing so opting for coilovers Link to comment Share on other sites More sharing options...
Neil-NA Posted July 26, 2011 Author Share Posted July 26, 2011 just fttied tein lowering springs to mine and 100% not happy with them.its dropped hardly nothing so opting for coilovers Cant say i'm at all happy with them either but i will be asking CW to get me some springs made after suprapod is out the way Link to comment Share on other sites More sharing options...
nigelboyne Posted July 26, 2011 Share Posted July 26, 2011 Cant say i'm at all happy with them either but i will be asking CW to get me some springs made after suprapod is out the way could you put the tt tein springs in cant see any problem Link to comment Share on other sites More sharing options...
ripped_fear Posted September 4, 2011 Share Posted September 4, 2011 bumping you thread as you advised me to come an have a look. Did it turn out you had TT springs or is the amount of drop you have listed is for N/A springs? Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 4, 2011 Share Posted September 4, 2011 just seen this.when i fitted my tein springs it dropped straight away with no settle time at all? i thought at first it would and did but it was just my eyes. Link to comment Share on other sites More sharing options...
