Coolant mixture
Guest Martin F
Guest Martin F
I seem to hear differing ratio's to mix this stuff up at, some say 50\50 some say 20\80 and some say 40\60.
Well today when i go to my local helpful Toyota dealer and buy 5L of the red coolant it says 'Pre-mixed' on the container. So am i paying for lots of de-ionised water as well ?
Does anybody know what the best ratio is ?
With our climate and without any other information I would go 50/50 or 40/60 if I was feeling tight that day.
Doesn't the good (hand)book suggest a ratio?
Pre mixed coolant? Hmmm. That's right up there with pre-grated cheese!! :-)
Guest Martin F
Handbook says 50\50, but i'm looking more for cooling capability than i am low temperature ability at this time of year.
I think it works both ways. The more concentrated the coolant, the better it should perform in hot climates too. Its actually that I was thinking of when I was typing.
I have been working on an engine for a hot climate recently. I'll double check that its the case tomorrow.
Its official. I was talking out of my a*se.
Although there is a slight improvement in cooling with increased concentrations, the concentration for hot countries is much lower (20/80).
Sorry for the mis-information.
Guest Martin F
Quote: from Barry on 9:14 am on April 12, 2002[br]Does anyone know if the cylinder head is an ally one.?  If it is, then you should never put water in the cooling system, it will corrode it eventually.  Just use the premix stuff if so. :)
The coolant does have some sort of inhibitor in it to reduce risk of corrosion. Also i would never use tap water as this would certainly increase the chance.
I not that clued up on how different metal's react, I just remember being told never to use water (tap or distilled) in a cooling system where the cylinder head is an ally one.
I always used Renault's pre-mix coolant on my 5 turbo as it had an ally head, it was about £12 for 5l.
Pre-Mix IS a mix of Anti-Freeze/"Summer Coolant" and De-Ionised Water.
The very reason Toyota (and most BIKE manufacturers i.e. performance machines) only recommend pre-mix is so you're not tempted to use tap water.
It's the 'coolant' which inhibits the corrosion by the water.
We get LOTS of work from everyday car drivers who think Anti-Freeze
is only for the winter !!
The first/main item to suffer is usually the water-pump because it's cavitating the water and so causes electrolysis around it's blades/bearing/housing.
WE JUST LOVE PEOPLE WHO DON'T USE ANTI-FREEZE . . ! !
[sort-of-pays for my Supra . . . .]
BUT, YES, will also corrode the ally/alloy head/block/housings FAR
less if reasonable amount of Coolant kept up.
The main reason for not using tap-water is to prevent radiator/heater-matrix from blocking (the 'blockage' is part rust and part 'scale' or 'hardness').
De-Ionised = NO hardness.
