psymon Posted July 12, 2005 Share Posted July 12, 2005 My Jap spec battery lasted only 6 weeks before dying a terrible death due to the alarm etc. I have replaced with an HBC005 and new battery connections. (I only bought one of these batteries 6 months ago for my scoob) :thumbdown Anyways everything is fine with the exception that when I close the bonnet, and start her up there is a slight vibration on the bonnet. I am sure the bonnet is not touching the terminals. but if you push down the front of the bonnet were the two catches are there is play. How do I adjust these to hold the bonnet down tighter. Thanks Quote Link to comment Share on other sites More sharing options...
Todd Posted July 12, 2005 Share Posted July 12, 2005 I had a problem with the bonnet not catching right on one side and there is very little play in the adjustment of the catches (3 screws). Found that just letting the bonnet go from a slightly higher height cured the problem but don't slam it down with your hand as dead easy to dent the bonnet. HTH Todd Quote Link to comment Share on other sites More sharing options...
merckx Posted July 12, 2005 Share Posted July 12, 2005 Are you sure you're pushing it down firm enough so the bonnet catches can hold it down. Careful you don't put a dent in it. On each side near the wing there is a rubber stop which can be turned to lower or lift up , this should stop the bonnet from vibrating. Quote Link to comment Share on other sites More sharing options...
psymon Posted July 13, 2005 Author Share Posted July 13, 2005 Cheers Guys. Forgot all bout the rubbers most cars have got em , DOH!!!!! will have a gan der today Quote Link to comment Share on other sites More sharing options...
