Thomas.B Posted July 22, 2011 Share Posted July 22, 2011 Hey all. I was just going to change my thermostat and removed the air-intake etc but I can hardly get my hand in! Some guys on here said they got it out that way but I cant see how I can get the bolts off as they are in an angle....? Dont want to remove the generator as I dont have the special tools... Any help would be nice Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted July 22, 2011 Author Share Posted July 22, 2011 Finally got it off from underneath the car Are aftermarket thermostats (from chris) supposed to be smaller then original? Quote Link to comment Share on other sites More sharing options...
dude Posted July 22, 2011 Share Posted July 22, 2011 No they need to be the same size, or at least the same size when they are in their little rubber ring. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted July 22, 2011 Share Posted July 22, 2011 Dont want to remove the generator as I dont have the special tools... Special tools? You just need 2 or 3 different size Spanners to get the alternator of. It's AFAIR 3 bolts that hold it in place, 1 bolt that holds the cable that goes to the battery and the connector. Quote Link to comment Share on other sites More sharing options...
dude Posted July 22, 2011 Share Posted July 22, 2011 Special tools? You just need 2 or 3 different size Spanners to get the alternator of. It's AFAIR 3 bolts that hold it in place, 1 bolt that holds the cable that goes to the battery and the connector. He prob means the torx bolt at the bottom, far easier to undop that than try slide it off. Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted July 22, 2011 Author Share Posted July 22, 2011 Ok have assembled everything and was going to check if it works anyway, need the car running soon. I got in contact with the alternator when reassembling everything and now the car wont do anything... checked the main fusebox under the bonnet and the small fusebox in the car... Am I missing something? Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted July 22, 2011 Author Share Posted July 22, 2011 Update: Nothing works, the turbotimer flashen on and then dies, no dashlights or anything. warning lights work and also headlight. Cant find any broken fuses... what can be the problem? Quote Link to comment Share on other sites More sharing options...
