Tyre sizes
SMW
Anyone else have 18" Blitz Z1 Technospeed alloys on their car?
I need new rubber and and the existing set are too skinny for the wheels IMO.
Wheel's are 10" rear and 9" front.
Current tyres are 265/35/ZR18 rear and 235/40/ZR18 front. (Toyo Proxes T1-S)
Is there a recommended tyre size for the Supra with this size of wheels? (I'm thinking along the idea of rolling radius which I think has been mentioned before on here, can't find the thread though.)
Definitely need wider rubber as I've kerbed 3 of the wheels due principally because the tyres I have don't afford any protection to the rims..............ouch:(
They might look skinny but that's not always the thing to consider. I've gone from 255-285 on the rear and noticed that my top-end has been slowed.
If you're not running out of grip then no need for bigger tyres. And if you are then that's probably more to do with the compound than the size.
I think it's more a case of running out of tread than having insufficient grip, interesting what you say about stunting the top end though.............couldn't be doing with that:)
Most places don't seem keen to fit anything other than the sizes that I have, so I'll probably go with another set of the Toyo's.
Thanks.
The stock profiles were 45-front and 40-rear on 17's. When I went upto 18's I dropped the profile to 40-front and 35-rear.
This setup works fine. If you chose any other profile on 18's then your speedo would probably show too much of an error in actual travelling speed.
I have exacly the same wheels as you sir running the same tyres size but there Pirreli p zero rossos.
The car seems to stick to the road like something that sticks alot.
I do have this suspension Tein Adjustable coilover suspension 'Type HA' sport spec
But the tires are amazing come rain or shine.
I will never by another tyre ever!!!!
