Guest farnell182 Posted July 20, 2011 Share Posted July 20, 2011 Hi, sorry if this is in the wrong topic, but could somebody have a quick look through this add and let me know what you think? I know there's not much you can tell from pics, but any help will be appreciated! It's no supra..but still toyota lol http://www.esperformance.co.uk/car_Celica-GT4-Toyota_162_0_index.php Any info appreciated thank you Quote Link to comment Share on other sites More sharing options...
sammytruck Posted July 20, 2011 Share Posted July 20, 2011 (edited) Hi ....Well it looks a lot of car for £2.5 k.........If you are seriously thinking of buying car why not put a deposit down on the understandingthat you will have an engineers report done, if report shows something untoward or something not disclosed ....take money and run...good luck. Edited July 20, 2011 by sammytruck grammar...oops (see edit history) Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 2, 2011 Share Posted August 2, 2011 I thought all gt4's came with blocks on the spoiler? or is it because its an import? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 3, 2011 Share Posted August 3, 2011 Well its had the figure 8s done which is an expensive headache, but no mention of a clutch change, Id check that as its an engine out job to replace it. Otherwise looks like a nice car Quote Link to comment Share on other sites More sharing options...
kill1308 Posted August 3, 2011 Share Posted August 3, 2011 I thought all gt4's came with blocks on the spoiler? or is it because its an import? The blocks on the spoiler were on the WRC edition I believe... along with the other differences below Bonnet spoiler Water injection nozzle in the inlet manifold Intercooler spray bar non-functional pieces for an Anti-Lag setup used on the WRC cars (required for homologation) Edit : looked on another forum and added water injection nozzle in the inlet manifold. Don't quote me on the above though, I don't acutally know for sure, just going on what I've read over the years as I looked at getting one when I was younger. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted August 3, 2011 Share Posted August 3, 2011 (edited) The WRC editions also came with either the Toyota Chargecooler unit or in uber rare cases the TTE chargecooler that was slightly bigger, from looking at the pics its got the stock chargecooler unit. one thing to check is the water pump to the chargecooler, its mounted on the gearbox. Usually these are throttle controlled however a few of the cars I looked at a while back had the pumps converted to run all the time, this car wear the bearings out and make the pump whine excessively so one to watch. Its these chargoolers from the ST205s that the MR2 lot nick and stick on their cars one thing to get checked out is the figure of 8 suspension, if it needs replacing your looking at almost £1k. Edited August 3, 2011 by TubbyTwo (see edit history) Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 3, 2011 Share Posted August 3, 2011 Well its had the figure 8s done one thing to get checked out is the figure of 8 suspension, if it needs replacing your looking at almost £1k. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted August 3, 2011 Share Posted August 3, 2011 That will teach me not to speed read posts Cracking cars tho, serious grip off the line as well. Quote Link to comment Share on other sites More sharing options...
straightsix Posted August 7, 2011 Share Posted August 7, 2011 PM me if you like - I've owned a few GT4s. Check out GT4OC.net too Quote Link to comment Share on other sites More sharing options...
Guest Dave J Posted August 7, 2011 Share Posted August 7, 2011 Well its had the figure 8s done which is an expensive headache, but no mention of a clutch change, Id check that as its an engine out job to replace it. Otherwise looks like a nice car "Absolutely no mechanical issues, the figure of 8's, clutch, cambelt, water pump, exhaust, discs, pads and tyres have all been replaced within the last few thousand miles so there are none of the usual mechanical bills looming around the corner!!" :o) Quote Link to comment Share on other sites More sharing options...
