greddy E-01 - how does it work?
Guest jakewilks
Guest jakewilks
hi
just got a supra TT 400 bhp, import , the car has a boost control knob with blue light and green light under steering wheel, also greddy e-01 system with memory card, and remote controller, and no instruction manual, the boost is making the car unstable to say the least, tyres are rear, dunlop sp9090 285x35x18 front sp9000 245x40x18 grip is terrible even in dry, any ideas how to lower boost, is it just the knob under st/wheel or do i need to go into the greddy set-up, a thing I do not want to do without info, is there a way to render the car as standard boost etc, as the knob on steering wh controller was set to full knob and green led lit, when I got it, and I dont want to adjust anything without knowing if i am screwing with the greddy e-01 controller, can I adjust the st/wheel controller without it affecting the e-01
any suggestions?
john
Guest jakewilks
Can you tell me how to lower the boost, and does this set up only work on the 2nd turbo?
Thanks for the manual, double Dutch at the moment, will look through it tonight,
John
