95supra Posted July 20, 2011 Share Posted July 20, 2011 okay so people always say they are running in Sequential mode or TTC. I know that with one mode both turbo's spool at the sametime. In another mode one turbo will spool up first followed by the 2nd?? So lets say I get my car tuned. Is there a electric control I can get to switch between Sequential and TTC? also which mode is better to run in? I am new to turbo Supra's so trying to understand this better. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 20, 2011 Share Posted July 20, 2011 Which mode is betteris purely a matter of tatse, some people love TTC others prefer the minimal lag and that 2nd turbo rush. Not sure theres an electronic way of switching, its just moving a couple of pipes around. Quote Link to comment Share on other sites More sharing options...
Guigsy Posted July 20, 2011 Share Posted July 20, 2011 Not many people run ttc all the time. And not everyone like it as it is a bit unresponsive and laggy iirc. your essentially making the system perform unlike it's intended I think the only way you are able to electronically swap between the two is with a ecu and remap? £££. Could be wrong Quote Link to comment Share on other sites More sharing options...
mawby Posted July 20, 2011 Share Posted July 20, 2011 You can electronically switch between modes, but this obviously won't adjust the mapping to suite the selected mode. An example here. Quote Link to comment Share on other sites More sharing options...
Supranature Posted July 20, 2011 Share Posted July 20, 2011 Might be an idea to learn how the system works http://www.max-boost.co.uk/max-boost/supra/turbo.htm Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 20, 2011 Share Posted July 20, 2011 I liked TTC. I found it better than the sequential setup for everyday driving. Better MPG and a more predictable power curve so easier to launch and modulate throttle inputs through corners. I did have mine mapped though, and that's essential to get to best from it. On the other hand, it is noisier and it is obviously more laggy, but I've also seen slightly better power figures from TTC. Quote Link to comment Share on other sites More sharing options...
Nic Posted July 20, 2011 Share Posted July 20, 2011 I use to run mine in TTC as I preferred the more linear power delivery, you do lose a fair bit of low down response but gain through mid rev range. Mine was mapped to suit TTC setup, I wouldn't run TTC with the stock ECU. Quote Link to comment Share on other sites More sharing options...
Ricky49 Posted July 20, 2011 Share Posted July 20, 2011 I ran TTC with the stock ecu and never had any issues. I didn't like it though too laggy and noisey. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted July 20, 2011 Share Posted July 20, 2011 I liked TTC. . I did have mine mapped though, and that's essential to get to best from it. Exactly, got to have it mapped for TTC to see the best out of it Quote Link to comment Share on other sites More sharing options...
Rajinder Posted July 20, 2011 Share Posted July 20, 2011 I run TTC mode (absolutley love it) some time and always on the track and I get faster times in the TTC mode. I run with the stock ECU, the car has not been mapped for TTC and no problems at all in last 4 years. Quote Link to comment Share on other sites More sharing options...
The-Plethora Posted July 20, 2011 Share Posted July 20, 2011 I ran for a year on TTC and a year on sequential, I think both have their bonus points. TTC seemed louder, slightly better MPG and when it kicked in it really was a nice instant kick but you have to have a heavier right foot to get the most out of it. Sequential is amazing low down, slightly worse MPG if you are hammering it and loses a bit of 'drama' somehow but you cant beat that low down turbo spool. I am currently running sequential. Quote Link to comment Share on other sites More sharing options...
