Clay says where's me oil coming from?????????
clay
Hi All
thought I should ask this question,
on the way to Tracy's (TJP) BBQ on Saturday evening, after a spirited drive down the M20, (at no more than 70 officer) HONEST guv, cos i know a police man,,,,,,,, but may have hit 140 on private land,,,,,
I seem to have developed a small oil leak "opps", and although the visual affect was entertaining when i arrived as the oil burnt off the exhaust, I thought I should investigate,
having had the car on a lift last night and cleaned off what appears to be trans fluid from under the car and the back panel, I have it back on the lift tonight having travelled approx 40 miles and can see no further signs of the leak,
So question is any ideas?
trans fluid in the box and what has leaked out is still pink, and does not smell burnt,
and the box is performing as well as it always does,
could it be i drive it to slowly??????????
Clay
This may seem a daft question, but do you run 4 life coolant? I made the mistake once thinking I had a transmission fluid leak when in fact it was 4 life coolant *.*ing out. On first observation the 2 fluids are very similar.
Ah i do youse for life and i must admite I ashoumed it was trans fluid. I hav checked trans fluid level and is only gon down a bit. the fluid seemed to be comming from the jount between the gearbox and bell houseing.I just thout it stange its never dun it befor. LOL I do check the trans fluid every week. THANKS FOR YOUR ASSISTANCE
That would not be good, thats a gearbox seal.
