b.weeks Posted July 18, 2011 Share Posted July 18, 2011 Hi all, what's the best oil to use for this, and where can I source it from? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 18, 2011 Share Posted July 18, 2011 I've moved this to the 'technical' section rather than the ICE one and changed your title so it's easier to search for in the future. Quote Link to comment Share on other sites More sharing options...
b.weeks Posted July 18, 2011 Author Share Posted July 18, 2011 Oops, ta. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 18, 2011 Share Posted July 18, 2011 (edited) I have the same Diff (1.5 or 2 way) not sure but its the Carbon ats one! I run Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140)-- no chatting, no issues; 75W 140 is recommended by them a few times in the Carbonetic manual http://www.opieoils.co.uk/p-736-castrol-syntrax-limited-slip-75w-140-formerly-saf-xj-75w-140.aspx If you want a cheaper oil Motul PA 90 does the trick but I find it does not last near as long!! Its a mineral oil, but oil in the LSD runs its course alot quicker How are you finding the ridicolous frequency of lsd oil changes! Like running a race car, carbonetic told me If it is new, then the oil would need changing at 200 miles. After the first change the second and third is 1500~2000 miles. And after that it is 2000~2500 miles. When the carbon LSD is new, there will be carbon powder in the oil and and this can damage the LSD gears. Edited July 18, 2011 by Jellybean (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 18, 2011 Share Posted July 18, 2011 Heres the list of oils Carbonetic recommends; Opie oils recommended I use the Castrol Syntrax Limited Slip 75W 140 based on the list below; no issues !! 2 years on Recommendation off Carbonetic All you need is GL-5 85W-90 oil for your LSD. If you cannot find that, the following will be suitable for the LSD; used Brand Name products name Viscosity FR BP X9140S 80W-140 FF BP X9118S 75W-90 FR/FF NUTEC UW76 75W-140 FF ADVANTAG NEO Hi proof shock FR ADVANTAG NEO RHD 75W-90 FR/MR A.S.H 250R 85W-140 FF/FR TOTAL PRO-R 75W-140 Quote Link to comment Share on other sites More sharing options...
b.weeks Posted July 18, 2011 Author Share Posted July 18, 2011 Ta mate. Very useful! Previous work (services) was all done elsewhere. You know anywhere that sells GL-5 85W-90 online? How many litres does a diff take? Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 18, 2011 Share Posted July 18, 2011 Ta mate. Very useful! Previous work (services) was all done elsewhere. You know anywhere that sells GL-5 85W-90 online? How many litres does a diff take? Tried everywhere , you can use Castrol Syntrax Limited Slip 75W 140 (Formerly SAF-XJ 75w-140) or Motul PA 90;Castrol is what I use! Good stuff, lasts longer Diff takes just under 2 liters Quote Link to comment Share on other sites More sharing options...
b.weeks Posted July 26, 2011 Author Share Posted July 26, 2011 Did some investigation work when I was back in the UK. Attached are some photos of the diff housing so you can see what size it is. We also replaced the oil. On draining the oil it was pretty thick, burnt and ionized so most likely contained filed bits of metal. We didn't have time to take the diff off and inspect, but we stuck a small camera into the housing and you can see the other attached pictures. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2011 Share Posted July 26, 2011 Thats normal the thick black oil and the fillings, the fillings are from the carbon disks. It says in the manual dont worry if you see fillings plus the oil is very black and thick Its in here on page 1; http://www.carbonetic.net/tech/pdfs/Carbon_LSD.pdf It also states you change your oil every 3k Km or 1870 miles;its a pain in the ass. Mine is overdue an oil change but I dont have any noise as of yet (indicator of an oil change), all these oil changes can get very expensive , if I could afford it I would get a TRD LSD, I think you only change the oil once a year on average(hopefully somebody will correct me) Quote Link to comment Share on other sites More sharing options...
b.weeks Posted July 26, 2011 Author Share Posted July 26, 2011 The knocking went away originally but has returned unfortunately. I think the 3 pictures actually show some of the components in there are knackered, need to open it up and have a full look. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2011 Share Posted July 26, 2011 The knocking went away originally but has returned unfortunately. I think the 3 pictures actually show some of the components in there are knackered, need to open it up and have a full look. When you say knocking, I presume you mean chatting within the LSD I tried 1 or 2 oils and forst change I used the incorrect oil, the LSD made one hell of a racket , knocking and banging but as soon as I put in the correct Oil (Castrol Syntrax Limited Slip 75W 140 or Motul PA 90) she went back to zero chatting , smooth and quiet ! I would still recommend the Castrol over the Motul PA90, I found the LSD smoother but the castrol is nearly double the price! I am sure the Motul Gear competiton would be just as smooth but it is crazy $$$ Quote Link to comment Share on other sites More sharing options...
b.weeks Posted July 26, 2011 Author Share Posted July 26, 2011 The knocking/clonking is on tight slow forward turns. Sounds like it's a welded diff. I have some Castrol, but didn't receive in time, so had to put some slightly thicker stuff in the the meantime. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 26, 2011 Share Posted July 26, 2011 The knocking/clonking is on tight slow forward turns. Sounds like it's a welded diff. I have some Castrol, but didn't receive in time, so had to put some slightly thicker stuff in the the meantime. That sounds like what happened to me when I put in the wrong oil! You would only really notice the clonking at slow speed, the slower u go the worse it was; Scared the crap out of me, I taught the Diff was FUBAR Quote Link to comment Share on other sites More sharing options...
