V161 Oil?
Guest Bigturbo
Guest Bigturbo
Hello guys,
a question that oil recommended for the V161?
Liqui Moly Getriebeöl ATF Top Tec 1200
Castrol Transmax Z
75W-90 TDL HYPOID LIQUI MOLY
Toyota ATF type 4
among them 4 are undecided what you use?
Just check the FAQ section:
Alternative:
Esso Dextron D21065
Royal Purple SynchroMax
BMW oil called MTF-LT-1 or LT-2
Castrol Transmax Z - Feedback required from testers
Mobil ATF 220 - Feedback required from testers
Plus Paul Whiffin has the V160 oil on stock I think...
I personally wouldn't recommend anything else...
Edited by EMPEROR (see edit history)
