hagar Posted July 17, 2011 Share Posted July 17, 2011 i own a 1jz mk3 supra and am in the middle of updating it. my water pump also has an oil pump attached that i wanted to remove. people use the 2jz pump and an electric fan in the mk3 world and i was wondering if there is a heavy duty 2jz water pump around as i plan on upping the horsepower a bit? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 17, 2011 Share Posted July 17, 2011 Stock water pump will be fine, get a Soarer 1JZ pump, viscous fan, job done Quote Link to comment Share on other sites More sharing options...
hagar Posted July 17, 2011 Author Share Posted July 17, 2011 i'm planning on getting away from the viscous fan hence the need for a pump without the oil side of things, i just want a simple water pump! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 17, 2011 Share Posted July 17, 2011 There is no oil side of things on a viscous fan, its a self contailed unit that bolts to the water pump. Im guessing your cooling fan is hydraulic powered like the Aristo/V8 Soarer? The stock 1/2JZ water pump is just that, a simple pump. Quote Link to comment Share on other sites More sharing options...
hagar Posted July 20, 2011 Author Share Posted July 20, 2011 the 1jz is a combined oil and water pump, the 2jz is a simple water pump. viscous fan no good as the waterpump is mounted off to one side. i was planning on putting 3 slimline electric fans (1 large 2 small) onto the rad itself. i have bought a 2jz fan this morning and will fit that on. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted July 20, 2011 Share Posted July 20, 2011 The Soarer 1JZ doesnt have the hydraulic cooling fan Look at the SRD electric fan thread, maybe that can help you Quote Link to comment Share on other sites More sharing options...
