barneybrendan Posted July 16, 2011 Share Posted July 16, 2011 I am no longer going to be using this as i am putting my gauges where the stereo went now.There is a slight crack appearing which will be an easy fix. £60 postage might not be a good idea, but i have some thick ply here i could cut to go either side and then wrap it. Link to comment Share on other sites More sharing options...
gjp Posted July 16, 2011 Share Posted July 16, 2011 A very good price and hard to get hold of. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted July 16, 2011 Share Posted July 16, 2011 What size gauges does it take? Link to comment Share on other sites More sharing options...
barneybrendan Posted July 16, 2011 Author Share Posted July 16, 2011 mine are 52mm Link to comment Share on other sites More sharing options...
barneybrendan Posted July 17, 2011 Author Share Posted July 17, 2011 Just to add this replaces the actual trim that is fitted originaly Link to comment Share on other sites More sharing options...
CanisLupus Posted July 17, 2011 Share Posted July 17, 2011 Shame it's just for 52s Link to comment Share on other sites More sharing options...
Supranature Posted July 17, 2011 Share Posted July 17, 2011 Would really like this Barney, can you show me a pic of the split? Link to comment Share on other sites More sharing options...
barneybrendan Posted July 17, 2011 Author Share Posted July 17, 2011 pic of split. Link to comment Share on other sites More sharing options...
Supranature Posted July 17, 2011 Share Posted July 17, 2011 Thanks for the quick reply. How easy a fix would it be to completely eradicate the split, and will it only fix with screws, or does it have the stock mounts? Link to comment Share on other sites More sharing options...
barneybrendan Posted July 18, 2011 Author Share Posted July 18, 2011 the crack should be an easy fix to totaly iradicate it.It didnt really need the screw and i wish i didnt bother as thats what caused the crack.it has stock mounts. Link to comment Share on other sites More sharing options...
Noz Posted July 18, 2011 Share Posted July 18, 2011 you could easily smooth the crack over with filler and give it a respray. wouldnt take much time as i just made one of these. well worth a buy GLWS Link to comment Share on other sites More sharing options...
Noz Posted July 18, 2011 Share Posted July 18, 2011 thinking about it you might even be able to spray it with filler primer (thicker than normal primer) and sand that. that would be an easier option to be fair. Link to comment Share on other sites More sharing options...
barneybrendan Posted July 18, 2011 Author Share Posted July 18, 2011 thinking about it you might even be able to spray it with filler primer (thicker than normal primer) and sand that. that would be an easier option to be fair. it would probably just glue back an the as you say just some primer and spray again.then as the paint is drying stipple it a bit . Link to comment Share on other sites More sharing options...
Supranature Posted July 18, 2011 Share Posted July 18, 2011 Ok I'll take it. Link to comment Share on other sites More sharing options...
barneybrendan Posted July 18, 2011 Author Share Posted July 18, 2011 Ok I'll take it. pm sent Link to comment Share on other sites More sharing options...
Robzki Posted July 19, 2011 Share Posted July 19, 2011 Dagnamit, my wanted posts always get missed, and at £50 I would have pasloded it to the A-post........ Link to comment Share on other sites More sharing options...
barneybrendan Posted July 20, 2011 Author Share Posted July 20, 2011 Dagnamit, my wanted posts always get missed, and at £50 I would have pasloded it to the A-post........ sorry Rob Link to comment Share on other sites More sharing options...
