Greddy template hole
Rob_Mitchell
i aint got the pipe work and i want to crack on. the instructions will do
The instructions are spot on, if you mark the centre exactly where is says you wont go wrong. You can use some cardboard as a template, make a hole in the centre and lay it in position then draw round it. Perfect :)
yeah mate i had the very same idea rattling around in my skull, the only measurment which will be tough is the 73mm from the bolt hole ( as there is no longer any holes ha ha)
ill be ok. Cheers for the instructions and help over the phone
