Oil light problem
Monster supra
On the right side of dash there are engine oil light , Gearbox oil light & the abs light
I have tested the bulbs which work
The circuit board is connected but when i turn the ignition all the other dash bulbs work
but not the board in question
Any ideas ?
yup - dry solder joints on the PCB connector. Common problem. :D
Also worth checking the connector as I have identified this on my car as a problem area.
Lights were working perfectly until I took the dash apart. Then this cluster didn't work at all unless i tapped the panel. Classic dry joint symptoms but some fiddling with the connector plug and all is now well. And has been for months.
Unless of course that is coincidence and they are dry joints! I'm certainly no expert on this.
More than likely yours is dry solder aswell. I done the same as you but they went again after about a year.
Best thing is get a solder iron (preferably with a pointed tipp) & just touch all the solder joints again, that should liquidise the solder & get rid off all your cracks :)
