drift_bear Posted July 15, 2011 Share Posted July 15, 2011 i bought this FCD http://www.sumopower.com/product/view/1933 but having trouble up here finding someone who is able to fit it, so my question is this, are they easy to fit and does anyone know where i can get a wiring guide/diagram to help me out doing it. im also looking at doing the BPU myself so need as much help as i can in doing it, i.e doing the fuel pump and where the RR goes on the de-cats. its got to a point now where im wanting to learn as much from my car as i can so i dont need to keep going back and forth to the garage for minor stuff and etc. any help from you lot would be great! Quote Link to comment Share on other sites More sharing options...
Mistermann Posted July 15, 2011 Share Posted July 15, 2011 http://www.mkivsupra.net/vbb/showthread.php?250725-HKS-fuel-cut-dender-and-general-BPU http://www.mkivsupra.net/vbb/showthread.php?94705-BPU-(Basic-Performance-Upgrade)&highlight=bpu Have you had a gander at these two yet? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted July 15, 2011 Author Share Posted July 15, 2011 http://www.mkivsupra.net/vbb/showthread.php?250725-HKS-fuel-cut-dender-and-general-BPU http://www.mkivsupra.net/vbb/showthread.php?94705-BPU-(Basic-Performance-Upgrade)&highlight=bpu Have you had a gander at these two yet? the first link you posted is just the link for this and the 2nd link about BPU i have already been through time and time again. still dosnt answer my question about setting up the FCD and if its an easy job or a pain in the arse! Quote Link to comment Share on other sites More sharing options...
Josh Posted July 15, 2011 Share Posted July 15, 2011 RR goes between 1st and 2nd cat. The diagram for the Thor FCD that I've bought doesn't look too complicated. Boost controller is a whole new story. I'm dreading it! Quote Link to comment Share on other sites More sharing options...
drift_bear Posted July 15, 2011 Author Share Posted July 15, 2011 RR goes between 1st and 2nd cat. The diagram for the Thor FCD that I've bought doesn't look too complicated. Boost controller is a whole new story. I'm dreading it! my boost controller is already plumbed in, just needs set up which shouldnt be to bad aslong as i get the english instruction lol did the thor diagram come with the FCD? mine is all in jap i think lol Quote Link to comment Share on other sites More sharing options...
Supranature Posted July 15, 2011 Share Posted July 15, 2011 The Gizmo FCD I bought came with detailed instructions for set up. If yours is a "Toyota" one as opposed to a Supra specific (think it is), then you need to alter the voltage clamp on it after it has been powered up. Do you have a multi meter? Where did you get the gaskets to add in the RR as a matter of interest? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted July 15, 2011 Author Share Posted July 15, 2011 (edited) The Gizmo FCD I bought came with detailed instructions for set up. If yours is a "Toyota" one as opposed to a Supra specific (think it is), then you need to alter the voltage clamp on it after it has been powered up. Do you have a multi meter? Where did you get the gaskets to add in the RR as a matter of interest? its the 1 from the site so it is a toyota fitment and yeah i have access to all the toolsi need. i was just going to use a normal gasket for doing the RR done a search on google to try find instructions and came back with this http://www.supramania.com/forums/showthread.php?113854-HKS-Fuel-Cut-Defender-Install Edited July 15, 2011 by drift_bear (see edit history) Quote Link to comment Share on other sites More sharing options...
Supranature Posted July 15, 2011 Share Posted July 15, 2011 Jeez, that link to "supramania"....... Think this needs to go in Tech so that greater knowledge can comment on that link.... Hang on, thats for fitting to a 7M_GTE! Quote Link to comment Share on other sites More sharing options...
black_widow87 Posted July 15, 2011 Share Posted July 15, 2011 http://www.hksusa.com/content/pdf1793.pdf Quote Link to comment Share on other sites More sharing options...
drift_bear Posted July 15, 2011 Author Share Posted July 15, 2011 http://www.hksusa.com/content/pdf1793.pdf yeah ive got that link aswell and i just found this aswell which makes it easier lol http://www.mkiv.com/techarticles/fcd/fcd.htm Quote Link to comment Share on other sites More sharing options...
