suprab Posted July 15, 2011 Share Posted July 15, 2011 my power steering at idle is extremely heavy (undrivable) just blip the throttle or hold higher revs and it perfectly normal until idle again,did anyone ever have a similiar issue? what was the fix, new pump? also this just happened out of the blue, was nearly home after a drive for an hour or so Link to comment Share on other sites More sharing options...
ManwithSupra Posted July 15, 2011 Share Posted July 15, 2011 Have you checked the fluid level? Link to comment Share on other sites More sharing options...
suprab Posted July 15, 2011 Author Share Posted July 15, 2011 sure have, its on the mark both hot and cold.. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2011 Share Posted July 15, 2011 You need to measure pump outlet pressure when turning the steering at idle. it could be the pump has a worn rotor, or it could be weepy rack seals. I could do this, but would need to make up a pressure adaptor, which I would have to charge for. To be honest the cheapest, quickest and easiest option is to take a risk and try a new pump. I would also make sure the gauze in the bottom of the fluid reservoir is TOTALLY clean and clear, (wash it out with brake cleaner, thinners, or petrol), and that the O ring and the pipe for the SUCTION side of the pump are perfect with NO air leaks allowing the pump to suck air. If it were to be doing this it would usually be noisy though. Is it noisy? Has it lost any fluid in use? Link to comment Share on other sites More sharing options...
suprab Posted July 15, 2011 Author Share Posted July 15, 2011 wow thanks chris, alot of info there, no it is not noisy at all and has not lost any fluid. this just happened after a good hour drive, lucky i was just turning into my drive when it went... now you can hardly turn the steering but tap the throttle and its normal. probably just bite the bullet and get a pump Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2011 Share Posted July 15, 2011 You should take the reservoir off and clean it out anyway. For the sake of a pint or so of fluid you could try it with the reservoir cleaned before buying a pump. New they are well over £300 + VAT. Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 15, 2011 Share Posted July 15, 2011 Rab, if you want to borrow the pump from my NA engine to see if it cures the problem you are more than welcome to it buddy. I think NA and TT pumps are interchangable if the fluid inlet is swapped over. It was definitely working fine when the engine was removed and you can hold onto if for as long as you need it to be certain yours is faulty. Link to comment Share on other sites More sharing options...
mellonman Posted July 15, 2011 Share Posted July 15, 2011 couldn't the crank pulley do this if was shot? Link to comment Share on other sites More sharing options...
Attero Posted July 15, 2011 Share Posted July 15, 2011 couldn't the crank pulley do this if was shot? The power steering is entirely lost when the crank pulley is shot. I would say this was the issue. Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 15, 2011 Share Posted July 15, 2011 You could just do a Tipex test to be sure it's not just slipping, rather than the outer rim come off altogether. Zero cost test Link to comment Share on other sites More sharing options...
suprab Posted July 15, 2011 Author Share Posted July 15, 2011 thanks everyone for all the advice, i will do some proper testing over the next few days and post up the answer, if i find one!! incase anyone else has the same symptoms Link to comment Share on other sites More sharing options...
suprab Posted July 15, 2011 Author Share Posted July 15, 2011 Rab, if you want to borrow the pump from my NA engine to see if it cures the problem you are more than welcome to it buddy. I think NA and TT pumps are interchangable if the fluid inlet is swapped over. It was definitely working fine when the engine was removed and you can hold onto if for as long as you need it to be certain yours is faulty. cool thanks, ill let you know how it goes and i may take you up on your offer Link to comment Share on other sites More sharing options...
pedrosixfour Posted July 15, 2011 Share Posted July 15, 2011 Ha! I'm gonna be totally honest here, you're not the Rab I thought you were! Theres two of you with virtually the same name runnin' around this site & this bloody country! I thought the other one just changed his avatar! But the offer still stands buddy! cool thanks, ill let you know how it goes and i may take you up on your offer Link to comment Share on other sites More sharing options...
