Slippery Posted July 15, 2011 Share Posted July 15, 2011 Have seen a few threads on here about people having a missfire through using different types of fuel so was wondering if this had any connection with mine. So does anyone have problems with using shell v power all the time or any other petrol. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 15, 2011 Share Posted July 15, 2011 Mine worked perfectly on V Power at stock, BPU and single levels. Do you have a different ECU? Have you checked your spark plugs? It may also be an issue with coilpack connectors. Quote Link to comment Share on other sites More sharing options...
Jamesy Posted July 15, 2011 Share Posted July 15, 2011 Was going to say possible coil packs or spark plugs. Although my wifes car (Cupra R Leon) runs like a bag of cr@p with anything other than super unleaded...has it been mapped for a certain fuel do you know? Quote Link to comment Share on other sites More sharing options...
Slippery Posted July 15, 2011 Author Share Posted July 15, 2011 Mine worked perfectly on V Power at stock, BPU and single levels. Do you have a different ECU? Have you checked your spark plugs? It may also be an issue with coilpack connectors. Stock ecu and has had new plugs coil packs and new clips in last couple of weeks. Quote Link to comment Share on other sites More sharing options...
AJI Posted July 15, 2011 Share Posted July 15, 2011 In my area the local franchise Shell garage seems to be selling 'different' v-power to other areas of the UK. I wrote a post about this a while back, but to cut a long story short, many sportscar owners in the area suspected the franchinse garage of selling cheapo octance fuel in the v-power pumps. There was various evidence for this but when customs&excise went to investigate they must have pre-announced their arrival (which sometimes they do apparently) as the tanks had usual v-power when they checked. (Well they didn't actuall do a chemical check actually, all they did was look at the delivery notes and take the garage manager's word that nothing was wrong ) So, if you don't find any other obvious issues then this could be something to bear in mind. Quote Link to comment Share on other sites More sharing options...
Slippery Posted July 15, 2011 Author Share Posted July 15, 2011 In my area the local franchise Shell garage seems to be selling 'different' v-power to other areas of the UK. I wrote a post about this a while back, but to cut a long story short, many sportscar owners in the area suspected the franchinse garage of selling cheapo octance fuel in the v-power pumps. There was various evidence for this but when customs&excise went to investigate they must have pre-announced their arrival (which sometimes they do apparently) as the tanks had usual v-power when they checked. (Well they didn't actuall do a chemical check actually, all they did was look at the delivery notes and take the garage manager's word that nothing was wrong ) So, if you don't find any other obvious issues then this could be something to bear in mind. Cheers that's very interesting cus I use the same garage all the time. May change every so often in future. Quote Link to comment Share on other sites More sharing options...
Supranature Posted July 15, 2011 Share Posted July 15, 2011 In my area the local franchise Shell garage seems to be selling 'different' v-power to other areas of the UK. I wrote a post about this a while back, but to cut a long story short, many sportscar owners in the area suspected the franchinse garage of selling cheapo octance fuel in the v-power pumps. There was various evidence for this but when customs&excise went to investigate they must have pre-announced their arrival (which sometimes they do apparently) as the tanks had usual v-power when they checked. (Well they didn't actuall do a chemical check actually, all they did was look at the delivery notes and take the garage manager's word that nothing was wrong ) So, if you don't find any other obvious issues then this could be something to bear in mind. Nothing surprises me this day and age. If thats true, is the owner aware of the damage he may cause to hyper-expensive engines? I doubt it, the pri........... Quote Link to comment Share on other sites More sharing options...
