damadom Posted July 14, 2011 Share Posted July 14, 2011 Hi all been trying to fit my spoiler today and wouldnt you know its a bugger to get on gave up in the end. right first question what size bolts do i need? and secondly can i take out the carbon middle section and put each end on singly? Matt Quote Link to comment Share on other sites More sharing options...
gjp Posted July 14, 2011 Share Posted July 14, 2011 Put each side on but not to tight, fit the blade then tighten the ends up. Quote Link to comment Share on other sites More sharing options...
damadom Posted July 14, 2011 Author Share Posted July 14, 2011 Will I be ok fitting it without putting anything to stop the paint rubbing like the normal spoiler has that rubber stuff? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted July 14, 2011 Share Posted July 14, 2011 did you buy the spoiler 2nd hand? did it come with anything else or just the 3 parts and nothing else? Quote Link to comment Share on other sites More sharing options...
damadom Posted July 15, 2011 Author Share Posted July 15, 2011 Bought it second hand only came with the three pieces. Quote Link to comment Share on other sites More sharing options...
comorin219 Posted July 15, 2011 Share Posted July 15, 2011 Will I be ok fitting it without putting anything to stop the paint rubbing like the normal spoiler has that rubber stuff? if you have nt got the foam/rubber seals it would be advisable to put a neat bead of clear silicon around the base about 5-10mm from the edge or your boot lid will take in water,if you let the silicon cure before fitting it will make a cleaner job Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted July 15, 2011 Share Posted July 15, 2011 You def need some sort of foam silicon for ends to sit on else as previously will fill boot with water. I used original bolts and fitted loosly then fitted blade and did up hand tight then about 1 full turn and checked after couple weeks and dun up a bit more. make sure you fit blade right way up to give downforce and not lift like a wing lol Quote Link to comment Share on other sites More sharing options...
damadom Posted July 15, 2011 Author Share Posted July 15, 2011 Well I've got the clear sealant but the standard Boyle are to small in diameter do you what width I'd need? Quote Link to comment Share on other sites More sharing options...
comorin219 Posted July 15, 2011 Share Posted July 15, 2011 my original bolts fitted my AM spoiler,guess its going to be trial & error try some other bolts by hand (just in case thread pitch is wrong) its probably the next size up from your original Quote Link to comment Share on other sites More sharing options...
Jellybean Posted July 15, 2011 Share Posted July 15, 2011 14 mm on mine; install the two posts first with either the center Blade loosened or taken off; then once the pillers are in, tighten up the center blade! I dont have any water ingress but if you want I would put some silicone around the holes on the inside of the boot or a rubber washer! I also run a square washer on the inside for the nut to have a resonable flat surface for it to press against; inside the boot lid is a concave shape Quote Link to comment Share on other sites More sharing options...
