hp006 Posted July 10, 2011 Share Posted July 10, 2011 The center console lights have decided they dont want to work. The fan aircon etc does i just cant see what is lite. I think the issue is where the dash has been taken in and out the wiring at the back of the dash is possibly coming loose. Does any one know which wire is for the lights so i can check this? Link to comment Share on other sites More sharing options...
add heywood Posted July 10, 2011 Share Posted July 10, 2011 Probably just a dry solder joint. Take out the plugs at the back and give them a wiggle see if it helps. Link to comment Share on other sites More sharing options...
hp006 Posted July 10, 2011 Author Share Posted July 10, 2011 I know when i push against the plugs and wiggle them the light comes back on but its getting it to stay on. Im about to fit a double unit and dont want to keep pulling the car about. Just wondered if any one new which one was the light so i can check that one. Link to comment Share on other sites More sharing options...
Guest bigsupe Posted July 10, 2011 Share Posted July 10, 2011 I have similar prob just fitted new head unit (headach!!)and have lost dash lights,air con and blowers i have checked fuses and all are good ??? Link to comment Share on other sites More sharing options...
marbleapple Posted July 11, 2011 Share Posted July 11, 2011 As Add Heywood says. I had the problems a few times. A real pain to take the dash panels off and all but you get it right eventually! Link to comment Share on other sites More sharing options...
