Which brakess do i have on my car? Pics attached
Guest cliogerbil
Guest cliogerbil
Hi
I bought my 1993 J-Spec N/A Manual about 3 years ago and the time has come for a brake overhaul. I'm not sure which brakes i have on it though and there seem to be so many options. I have attached pics below to see if i can get an answer.
Rear Assembly - I think 296mm on these but they are vented discs. I have heard they should be solid.
Front Assembly - Not sure but i think 296mm again and vented discs. they look pretty thick too so i dont think these need changing
[ATTACH=CONFIG]135610[/ATTACH]
[ATTACH=CONFIG]135611[/ATTACH]
[ATTACH=CONFIG]135612[/ATTACH]
Any help would be much appreciated
Cheers
Edited by cliogerbil (see edit history)
Guest cliogerbil
The specs are correct but the picture is wrong. I'd not buy something that cheap though, there's no way they're the right ones (or even useful) at less than £19 each. If you're strapped for cash the partco (pallitt I think) ones are okay, but even those are much more expensive, they are okay for road use though but I did warp a set in 2 laps at Bedford!
Guest cliogerbil
Hi again
I've found some mintex rear discs for £48 a pair which i thought were a bargain The link is here.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=190538785158&ssPageName=ADME:X:RTQ:GB:1123
I've been told by the same company that the pads to with them are Mintex MDB 1322. Is this correct or are they a different number?
£70 all in delivered to my door
Thanks for all your help on this one guys. VERY much appreciated. I think we're almost there.
