Suspension set up
ADD
Yes you would have all you have to do for the fronts is take out the one long bolt on the top suspension arm that's how's easy it is literally 15 minute job each side no need to remove drop links or use spring compressors
Ahhhhhhh I see :) that helped loads! All completed now. Although I have measure everything exactly the same when installing the suspension but the height on one side is more than the other!! I'm not worrying too much as it's got to settle first
Ad
Ad
I did mention this in post 7 :rolleyes: Pay more attention at the back :D
