It wasnt the bushes
markylee
Bought some superpro off bushes off paul whiffin for the rear toe arm (inner bush) as their was so much play in it , looks like the old bushes are ok but the cam bolt is worn, so check your bolts before you buy bushes guys ,,,,has anyone had the same problem? or is this pretty rare?
How did you check for play? I thought it was more or less impossible to see unless it was *really* bad?
Ifitted some hsd coilovers and when i put the wheel back on their was lots of play in it, i thought i had a bearing gone, but looked at toe arm and you could see it moving all over the place.
