Good Light Weight Battery?
JamieP
Yep that will be fine but you will probably get away with the 30, either way dont buy them from DT... way too expensive.
Extreme Racing 40 http://www.jjcraceandrally.com/Race_&_Rally/Autograss_Essentials/Batteries/Odyssey_Extreme_Racing_40_Battery/317/0/3159 £172.78 with VAT (Demon Tweeks £204.33 with VAT)
Extreme Racing 30 http://www.jjcraceandrally.com/Race_&_Rally/Autograss_Essentials/Batteries/Odyssey_Extreme_Racing_30_Battery/317/0/3161 £149.48 with VAT (Demon Tweeks £171.10 with VAT)
Oh an JJC do free delivery over £80 ex vat
Edited by ManwithSupra (see edit history)
Cheers guys, would this one do the job?
Braille B3121 Carbon Fiber Premium & Extreme Use Lightweight BatteryPERFORMANCE
Voltage: 12 volts
Full Charge Voltage: 13.8 volts
Short Circuit Current (Max Cranking Amps): 3000
Pulse Cranking Amps (PCA) 5 sec @ 80F: 1380
Pulse Cranking Amps (PCA) 10 sec @ 80F: 1207
Pulse Cranking Amps (PCA) 20 sec @ 80F: 1066
Cranking Amps 30 sec @ 80F: 892
Cranking Amps 30 sec @ 32F: 742
Cold Cranking Amps 30 sec @ 0F: 550
Reserve Capacity: 1hr &15minutes
Capacity (C/20 rate): 31 amp hr
Internal Resistance (ohms): 4 milliohms (.004ohms)
Life Cycle @ 10% DOD: Up to 3500 cycles
PHYSICAL SPECS
Carbon Fiber Heat-Resistant Casing, Horizontal and Vertical Mounting
BCI Group: Usable for all Group Sizes
Length: 6.6
Width: 5.1
Height: 6.8
Minimum Weight (lbs): 21 lbs
Post Type: SAE Automotive Posts included & 6 x 1.0mm racing bolts included.
Stainless Stud: Both Automotive SAE Posts and Race Style Bolts are Stainless with a 6 x 1.0mm bolt pitch
