Ford Focus Fault - Air box Bongo's!
pezzler
The Mrs' Focus has been running like poop for the past couple of months so I thought i'd give it a little service today
New Spark plugs
New leads
Air filter
Engine oil and filter
Fuel fiter
Drive belt
It now runs a little better, but I'm still getting the previous problem. When idling and at low RPM, i'm getting a chugging noise from the exhaust, and a low frequency "bonging" noise from the airbox - it really does run crappy on idle.
I thought i'd open up the airbox and have a better listen, and it does genuinely sound like theres a little fella in there, wailing away on a pair of bongo's!
I think it's an unusual one, but then i'm no mechanic. Any one have anything similar to this before? Just wanted a few possible suggestions, was convinced it was the coil earlier today but now i'm edging towards thinking maybe a vacuum leak but its way too late to go take a look now.
Cheers
Edited by pezzler
Crappy thread title (see edit history)
Replaced ignition coil
Cleaned down idle valve
Cleaned throttle body
Checked all hoses and manifold for air leaks
Still no joy - but seemed to run a little sweeter when I increased the air flow by removing one of the vacuum lines that go to the EGR (located after the butterfly). Guessing the idle valve is starving the engine of air. Had to reconnect the EGR pipe though as it is located downstream of the MAF sensor, didnt want to muck the mixture up too much. Focus' Rock!
Booked in for a professional to take a look, cant be doing with with this "replacing parts til its fixed" attitude
I think I have this guy lodged in the manifold somewhere
Edited by pezzler (see edit history)
