Fluid leak from inside edge of rear wheel
stevie_b
On my NA, I've spotted a fluid leak at or very near the rear driver's-side wheel. There's enough fluid to form a considerable damp spot on the ground over a couple of weeks of the car being stationary. I'm guessing this will be brake fluid, will it? I haven't had a chance to take the wheel off yet. I can't see it being hydraulic fluid from the shock absorber; it doesn't look like it's coming from high enough (see photo). It's just the horizontal bar thing that seems to be damp with fluid.
Any ideas what it could be? Is this a common problem? I've searched for it, but couldn't find any examples like this.
In my photo, is the brake pipe the pale looped pipe near the top of the photo? Access is a bit tricky where I have the car parked, but I'll take another look and try to be more specific about the source of it. It looks like the fluid is weeping from the right-hand join of the horizontal bar thing. (If anyone can let me know the proper names of these components that I'm talking about, that might help too! :))
The horizontal bar thing is the lower suspension arm, this fits into the hub using a ball joint.
It's almost definetly brake fluid as the arm is directly under the brake line, get the wheel off and have a good look.
Check out the WSM, suspension and axle section as theres nice diagrams in there showing all the bits you need to see
  • 2 weeks later...
