Not driven car for a year and cant push it out of driveway. Please help
Gazzawu
Hi there Iv left my car at my friend's for a year now and i tried to start it up but obviously wont start up cos battery is flat so tried to push it out into the road. Unfortunately gear wont shift from Park so had to press the red button until I could shift back to Neutral. Released the hand break and two of my m8s tried to push it......no luck..... just rocking movements. Tyres look a bit flat so they can do with more pressure. Can the brakes seize up if the car has been stationery for that long?
Any suggestions everyone?
Yeah breaks can sieze. But doesn't pressing the red button just move the shifter without changing gear?
I'm not sure I've never had a jspec auto
In this instance it does move you out of park, so you should be able to push the car - unless the brakes have seized.
you could try moving the car by turning the wheels by hand using the spokes. thats how i do it and its always worked better than trying to push. failing that just jack it up and free one at a time
Put a decent battery on it, check all fluids, disconnect ignition and turn over to get oil pressure up, reconnect ignition and fire it up and drive it out :thumbs:
:yeahthat:
Any other method will be a PITA!
Preventative maintainence is generally preferable though.
This is an excellent way of either loosing a finger or breaking one as they get caught on the caliper behind the spokes and the weight of the car keeps the wheel moving. BE VERY CAREFUL !!!!!!
I watched a recovery guy lose the tops of his fingers doing this, not a good idea at all.
