Is this the cause of my VVTi engine blow up?
Jake
Yeah...could well be...if it was only getting a atmospheric source it wouldn't have raised the pressure for boost. It would have driven fine off boost.
Shit, that's a real pisser if it was the cause.
Quick Q. Had you tinkered in that area that you can recall? Even cleaning it? Toyota don't clamp it so it should be able to come off of it's own accord....unless the FPR was blocked and caused the pipe to blow off.
WTF is T'd off it?
Argh, that could well be it :( On-boost you'd have lost a lot of fuelling... I saw a drop from 10.5:1 afrs to 12.5:1 by dialling the static pressure down 4psi - so dropping it by 14psi would be disasterous :cry:
I'd imagine it blew off while you were driving along, as it's difficult to start the car with it missing.
-Ian
-Ian
I thought mine started without it attached...
VVTI - that pipe goes the Fuel Pressure Up VSV (the one I want to borrow Jake ;) )
  Jake said:
Could this have been the cause of the engine going bang? :(
YES.
Having been experimenting with the vacuum of this hose (FPR compensation) I can say that without it at 10psi you're looking at AFR 15:1, and that's on a UK model.
If you were doing 1 bar or more, I'd bet it went into 18:1 and beyond, certain meltdown.
i started mine up the other day to move it into the garage with the boost controller head unit disconected which is connected to the FPR (so essentialy the same scenario) and the car would barely idle and was rough as hell, if you lost this pipe i would think you would notice
Like I said, you'd notice if it was off when you tried to start the car. Driving it is a different matter, it'd run over-rich on cruise but would still *run*. On boost it'd lean off though :thumbdown
-Ian
WTF is T'd off it?
Nope, no tinkering at all in that area.
WTF is T'd off it? The GReddy PRofec E-01 boost controller's vacuum pipe.
How gutted am I? If only I'd taken a look under the bonnet when the car started misfiring. I honestly thought it was bad fuel
:KicksHimself:
I've just twigged. That's K55 BYE isn't it?
I guess the only redeeming factor is how cheap you got the car for in the first place. You can build it back up stronger and be like new for a fair price in total. :thumbs:
Yeah that's the one mate. Doesn't look like I'm going to actually make money on this one now. :p
  Usmann A said:
Sorry to hear this Jake.
you reacon shell be back up and running for JAE/TOTB?
Nah mate, not this one. I've got a replacement lump to go in it but I can't afford to have it fitted at the moment. Unless I fit it myself it'll have to wait for a while.
My grey car is fixed now though (broken cambelt tensioner bracket) so I won't be Supraless for TOTB.
I'd have thought there was some sort of emergency 'limp' mode that would be activated if something like this happened.
Apologies for the mechanical retard post. Just seems surprising that a small air pipe coming off would have such immediate, terrible consequences.
Guest a71ak
I think there's a missunderstanding here guys ... I hope I'm not wrong because you got me confused since every one agreed to this .... :scare:
Jake this can't be the reason for the engine to blow ... because the disconnection of this vacuum pipe will increase the fuel pressure not decrease it ... Toyota re not that dump . :no:
Fuel pressure regulator is spring loaded to a certain pressure from factory the only time they need to decrease this pressure is during idle to have better idle, fuel consumption, emission control etc ... so to achieve that they connected it to the intake manifold to sence vacuum ... and this vacuum will suck the spring/diaphram down a bit to decrease the FB ... and since the only time you have vaccum is when your throttle closed at idle ... so in normal driving conditions the regulator well have no vacuum acting on it and the pressure will be higher.
Sorry for the dump explenation but Hope this help !!
Ali
  a71ak said:
..Jake this can't be the reason for the engine to blow ... because the disconnection of this vacuum pipe will increase the fuel pressure not decrease it ... Toyota re not that dump . :no:
Ali
Dude, if you want to explain something, don't you think you first need to understand it yourself?
That was a bit of an unnecessary insult, why did you think he didn't understand it himself :shrug: ?
Have I missed something?
Well the last thing you need in the 'tech' section is technical 'explanations' that are wrong or incomplete, presented as 'facts'.
Disconnecting that pipe will make it run lean as hell under boost.
Below is a supra setup with that hose effectively disconnected under boost (the one-way valve allows vacuum though)
http://www.max-boost.co.uk/stuff/FPR_fishtank_valve.jpg
Do you want to know the AFRs seen under boost? Brrrrr... :violin:
Why have they chosen to do this ? :)
