Sheefa Posted July 2, 2011 Share Posted July 2, 2011 Hi all Bought second hand a few months ago, ran flawlessly without smoke/excessive fuel burn. Approx 10 times of cutting grass. It ran out of fuel and I have now re-filled. Started really spluttering and smoke was quite excessive, just wasn't her normal self. Turn off and checked tank and re-primed, same issue. Then suddenly started running perfectly again for about 30 secs before cutting out. Inspected tank and completely empty despite filling it to top. This tank would normally do 5-6 full grass cuts front and back. A full tank only just managed the back garden this time. Seems odd when it's nearly at empty she runs brilliantly again. Any ideas guys? Cheers Greg Link to comment Share on other sites More sharing options...
Guest bradoz88 Posted July 2, 2011 Share Posted July 2, 2011 check the oil for petrol ? if there is petrol in the oil check the carb nedel as they can stick open allowing the fuel to entre the sump Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 3, 2011 Share Posted July 3, 2011 Is it a two or four stroke? Link to comment Share on other sites More sharing options...
buster Posted July 3, 2011 Share Posted July 3, 2011 Carb it has be. Take it all apart and give it a good clean with carb cleaner. i would exspect something will have been sucked from the bottom of your fuel tank. hope this helps Link to comment Share on other sites More sharing options...
dude Posted July 3, 2011 Share Posted July 3, 2011 Get a syvecs on it. Link to comment Share on other sites More sharing options...
GazB Posted July 3, 2011 Share Posted July 3, 2011 mine smokes when low on fuel, totaly abused with no maintenance and still running after 8 years I run mine on VPower for faster mowing Link to comment Share on other sites More sharing options...
tomgeer Posted July 3, 2011 Share Posted July 3, 2011 If you've had it tilted to one side or turned upside down for any reason they smoke like b*stards for about 2-5 minutes, just keep it running and see if it settles down. Link to comment Share on other sites More sharing options...
