Awesome Android App.. Alaprecorder HD
ManwithSupra
Came across this a little while ago and thought i would give it a try for a few weeks before i posted on this.
Basically it’s a Track Video recorder with the ability to overlay Speed & OBD sensors on the replay.
Or you can export the video file and csv file for use with other track overlay products such as Vbox software.
You can use an external Bluetooth GPS unit if you wish to get better more accurate speed readings (Internal GPS unit on the phone has a refresh of 1hz and the software recommend you have between 5 - 10Hz)
It has some of the UK tracks already in place with an Auto track selection based on your location via GPS.
So say if you are at Brands hatch it will automaticly select the track with all the time sectors, start/finish line etc, then once you are out on track press the record button at the start line and then it will start to log your lap. will calculate 0-60 time, track sector times, full lap times and compare them as well.
It also logs all OBD2 information (via Bluetooth OBD2 dongle) if your car is OBD2 (most Supra's are not) but it’s a nice feature anyway.
http://adyno.net/
https://market.android.com/details?id=net.adyno.alaprecorderhd
https://ssl.gstatic.com/android/market/net.adyno.alaprecorderhd/ss-800-0-9
https://ssl.gstatic.com/android/market/net.adyno.alaprecorderhd/ss-800-1-8
https://ssl.gstatic.com/android/market/net.adyno.alaprecorderhd/ss-800-2-7
http://www.youtube.com/watch?v=DiBXhuH1YRw&feature=player_embedded
I will get a couple of my video's up once i get around to exporting them.
