HSD HR Coilovers
pete_TT
HSD HR Coilovers
Used for less then 1500 miles.
Price: SOLD
Main features:
High quality monotube coilovers
16 stage adjustable damping front and rear.
Pillowball top mounts front and rear.
Adjustable preload on the spring perch, no need to compromise damper travel when adjusting ride height. This way, you can dial in the damper travel as required and then set the ride height independantly.
Wide ride height range, capable of catering for all needs.
Standard supplied spring and damper rates provide an excellent mix of on road useability with on track performance. Compliant damping allows the use of relatively firm spring rates on the road, yet with a higher damper setting they provide incredible response for circuit use. Damping adjustment is biased towards rebound, so provides a simple, easy to feel and understand damping adjustment for the end user.
Pics:
