Jamesy Posted June 30, 2011 Share Posted June 30, 2011 (edited) Ok i've had loads of pm's asking whats happened/happening with the car .... The engine managed to spin a bearing which was a bit traumatic to say the least. I will add at this point, just so people dont get scared into thinking 700hp+ on a stock block is going to blow - the engine builder has inspected the block and said its not due to absuse on the engine - so please dont let what happened to me put you off (no gaurantee's though ) So after this unexpected nightamre Lee @ SRD has again taken the car under his wing and the car is undergoing an engine re-build - Once its finished it will pretty much be a fully built engine, just without the uprated rods and pistons. Got to say a massive thanx to Lee already for squeezing me into his very busy schedule We had also planned to do a proper fuel system upgrade to the car so that is also happening while its at SRD. With both the improvements above i'm hopeful Ryan will be able to safely map the car to 2bar of boost and have some real fun this summer!! New fuel system will consist of: * -6 or -8 lines * Twin bosch 044's mounted inside the tank * Injector clinic 2150cc high imp injectors * Injector clinic fuel rail * New filters * Staged twin 044 set up The built engine will now be made up of: * ARP head studs * ARP rod bolts * ARP main bolts * ACL rod bearings * ACL main bearings * ACL thrust washers * New uprated rings * Fully balanced and line honed Its now got an SRD Stage 2 Race head consiting of * Full refresh * Re-cut valves * Shimmed * Skim * Fully ported and polished And while the Boostlogic gearbox is off we'll be fitting a new PI 3200 high stall TC Really looking forward to suprapod in a few weeks time Edited July 2, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted June 30, 2011 Author Share Posted June 30, 2011 My "original" plans for this year was just to get the front seats retrimmed in black leather and get a pair of 15" drag wheels...but with the work thats now being carried out they will prbably have to wait until next year!! Link to comment Share on other sites More sharing options...
Jamesy Posted June 30, 2011 Author Share Posted June 30, 2011 (edited) Twin 044's mounted - bit of a squeeze to say the least Edited July 1, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted June 30, 2011 Author Share Posted June 30, 2011 (edited) Just picked up the short block - all uprated parts fitted, line honed, painted and balanced Edited July 1, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted June 30, 2011 Author Share Posted June 30, 2011 Good to hear its getting sorted mate, lee is a top bloke. the bottom end should be bullet proof after all that, why didnt you go for new pistons/rods? i thought you might have done while its in that state Thanx Rob - yeah would have been ideal time for rods n pistons but not financially an option right now. Hoping all the uprated parts will be more than enough protection though Link to comment Share on other sites More sharing options...
mark newman Posted June 30, 2011 Share Posted June 30, 2011 Thats good to see you are sorted . Link to comment Share on other sites More sharing options...
JamieP Posted June 30, 2011 Share Posted June 30, 2011 Nice to see its getting sorted mate, what reason did the engine builder give for the spun shell? Link to comment Share on other sites More sharing options...
mikeyh Posted June 30, 2011 Share Posted June 30, 2011 i bet you cant wait. good luck with the build mate im sure things will be sorted soon Link to comment Share on other sites More sharing options...
Swampy442 Posted June 30, 2011 Share Posted June 30, 2011 Where did my post go?? Maybe saying balls is restricted now? Anyway full on Jamesy, best of luck with the build Link to comment Share on other sites More sharing options...
Bailey. Posted June 30, 2011 Share Posted June 30, 2011 It's a project thread, the mods delete 90% of posts that arnt direct to the project............. Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 Nice to see its getting sorted mate, what reason did the engine builder give for the spun shell? pm'd mate Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 Thanks guys - yes its getting there now.... ... the head has gone off to the engine builders this morning for a full refresh, valves and a skim so by the time its refitted the whole engine will be pretty much as new Lee is also doing a staged set up for the twin 044's to help avoid any issues of overheating the fuel. Link to comment Share on other sites More sharing options...
imi Posted July 1, 2011 Share Posted July 1, 2011 Nice to see its getting sorted mate, what reason did the engine builder give for the spun shell? would be interested in knowing why it failed too, could be a good lesson for others. Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 1, 2011 Share Posted July 1, 2011 Lee is also doing a staged set up for the twin 044's to help avoid any issues of overheating the fuel. Can you explain what 'staged' means mate? Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 1, 2011 Share Posted July 1, 2011 would be interested in knowing why it failed too, could be a good lesson for others. Same here... Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 (edited) Can you explain what 'staged' means mate? Lee or Jamie may explain this better but as far as i believe its so that one 044 is working up to a certain rev limit, and the other kicks in at higher rpm. As the 044's are so big, to have both of them running at low rpm, like in traffic casuing massive amounts of heat that is not needed, or wanted. I think Lee did the first staged set up on Jamie's car recently with very good results. Edited July 1, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 1, 2011 Share Posted July 1, 2011 Lee or Jamie may explain this better but as far as i believe its so that one 044 is working up to a certain rev range, and the other kicks in at higher rpm. As the 044's are so big, to have both of them running at low rpm, like in traffic casuing massive amounts of heat that otherwise is not needed, or wanted. I think Lee did the first staged set up on Jamie's car recently with very good results. Cool - cheers dude. It's always nice to have things broken down in threads like these Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 Cool - cheers dude. It's always nice to have things broken down in threads like these Anytime mate - its a steep learning curve for me!! Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 (edited) Fitted the new PI 3200 hi stall TC tonight Edited July 2, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted July 1, 2011 Share Posted July 1, 2011 so whats better with this hi stall compared to the 3800?? Link to comment Share on other sites More sharing options...
Jamesy Posted July 1, 2011 Author Share Posted July 1, 2011 Its just the one i wanted from the start mate as been out in Matts with it fitted, so as the gearbox was out it was worth swapping over Link to comment Share on other sites More sharing options...
Jamesy Posted July 2, 2011 Author Share Posted July 2, 2011 (edited) Had a right result tonight - went to SRD and the head has been finished - to a much higher standard than i first thought ....... Its now got an SRD Stage 2 Race head consiting of * Full refresh * Re-cut valves * Shimmed * Skim * Fully ported and polished The workmanship is stuning and im over the moon with it!! Edited July 2, 2011 by Jamesy (see edit history) Link to comment Share on other sites More sharing options...
Jamesy Posted July 2, 2011 Author Share Posted July 2, 2011 Now starting refitting parts to the short block Link to comment Share on other sites More sharing options...
JamieP Posted July 2, 2011 Share Posted July 2, 2011 Good to see it coming back together. Lee is fast, but ready for fast5? surely you will also need a remap mate? Link to comment Share on other sites More sharing options...
Jamesy Posted July 2, 2011 Author Share Posted July 2, 2011 Fitted the turbo kit and plenum to the head and then refitted onto the the block tonight so we're all set for a busy day tomorrow Link to comment Share on other sites More sharing options...
