G9RGE Posted July 9, 2005 Share Posted July 9, 2005 My headlights keep misting up when it rains or when i wash the car. Can you remove the glass in the same way as the jspec ones or are they sealed differently. Is the seal around the edge a pressure seal ie, the tighter you do the lights up the better the seal. I wouldnt mind taking them apart as some of the silver inside is going yellow and could do with touching up, just worried about cracking the glass. Anyone had the same prob? Cheers Quote Link to comment Share on other sites More sharing options...
Kev.O Posted July 10, 2005 Share Posted July 10, 2005 I had the same problem, so I put them in the oven. I cleaned them up and resealed them. They're now worse than before I done it! Quote Link to comment Share on other sites More sharing options...
G9RGE Posted July 10, 2005 Author Share Posted July 10, 2005 Sorry to hear that, think il probably still do the same and just keep my fingers crossed they end up better. I was mainly concerned about cracking the glass putting them in the oven, but if yours were ok then il give it a go. Cheers Quote Link to comment Share on other sites More sharing options...
Geezabloke Posted July 10, 2005 Share Posted July 10, 2005 Did mine this week and sprayed them at same time. So far so good? I did mine with a hot air gun and cardboard box over the top, leave for 10 minutes or so and pull apart .....TOP TIP........wear gloves at this stage.....lol Dave Quote Link to comment Share on other sites More sharing options...
Kev.O Posted July 10, 2005 Share Posted July 10, 2005 TOP TIP........wear gloves at this stage.....lol Dave Yeah tell me about it. Also, use old tools to prize the bits apart as the sealant sticks to everything Quote Link to comment Share on other sites More sharing options...
black cat Posted July 11, 2005 Share Posted July 11, 2005 are there any garages that do this in the uk, i have j spec facelift ones, not paying 600 quid for new but dont want uk. too scared to do it. tried nothin and all out of ideas!!!!!!!!. (homer simpson quote) tt steve. Quote Link to comment Share on other sites More sharing options...
Dale B Posted July 11, 2005 Share Posted July 11, 2005 My headlights keep misting up when it rains or when i wash the car. Can you remove the glass in the same way as the jspec ones or are they sealed differently. Is the seal around the edge a pressure seal ie, the tighter you do the lights up the better the seal. I wouldnt mind taking them apart as some of the silver inside is going yellow and could do with touching up, just worried about cracking the glass. Anyone had the same prob? Cheers Have you recently chabged the bulbs?. If theyre not seated properly or the seal has perished / cracked, when you turn the lights on the hot bulbs draw in moisture. I had the same problem and just reseated the bulbs. Quote Link to comment Share on other sites More sharing options...
The Restorer Posted July 11, 2005 Share Posted July 11, 2005 I had the same problem, so I put them in the oven. I cleaned them up and resealed them. They're now worse than before I done it! LOL. Can't be as bad as mine. I only did the one and touching up the yellow areas means I have two differently coloured headlights (one standard and one with silver flakes). Just waiting for an 8 hour dry day, when I'm free to do them both again properly!!! Quote Link to comment Share on other sites More sharing options...
