valve guide size
supra dan
Inside diameter 6.010-6.030mm. The valve stems should be 5.970-5.985mm for the intake, 5.965-5.980mm exhaust. Which gives a clearance of 0.025-0.060mm for the intake and 0.030-0.065mm for the exhaust. Stock guides are 38.5mm high for the intake and 40.5mm high for the exhaust. They are supposed to protrude 12.3-12.8mm on the intake and 11.4-11.8mm on the exhaust.
