Guest joey Posted June 26, 2011 Share Posted June 26, 2011 HAVING PROBLEMS LOADING PICS - THERE ARE PICS ON THE EBAY LINK AT THE BOTTOM OF THE PAGE, WILL GET THEM LOADED ON HERE ASAP THE WHOLE CAR IS AVAILABLE FOR PARTS SPEC - 1993 HONDA CIVIC EG4 HATCH D15Z1 ENGINE - FULLY FORGED - COVERED 400 MILES. FORGE LOW COMP PISTONS FORGE H-BEAM CONRODS ACL RACE BEARINGS FLOWED B2 HEAD REBORED & HONED NEW BEARINGS & SEALS STAINLESS J PERFORMANCE TURBO MANIFOLD T3/T4 TURBO 38MM WASTEGATE 240CC INJECTORS CUSTOM INTERCOOLER SET UP OBD1 CONVERSION WITH PO8 JDM ECU (HAS BEEN CHIPPED & HAS BASE MAP WRITTEN ON CHIP) ECU CONVERSION JUMPER HARNESS HKS SSQV LIMITED EDITION DUMP VALVE 38K MILE GEARBOX WITH BRAND NEW STAGE 4 CLUTCH (6 PUCK WITH NO SPRING ASSIST) AUTO GAUGE BOOST GAUGE IN PSI AUTO METER AIR / FUEL RATIO GAUGE TYPE R 5 IN 1 REV COUNTER WITH SHIFT LIGHT (OIL TEMP, OIL PRESS & WATER TEMP) REBUILT FRONT CALIPERS EBC DRILLED & GROOVED DISKS BLACK DIAMOND UPRATED & OVER SIZED PADS CUSTOM MADE SWITCH PANEL WITH 3 AVIATOR TOGGLE SWITCHES & START BUTTON ENGINE NEEDS THE CAMBELT PUTTING ON AND TIMING SOME BITS OF CARBON WRAP IN THE CAR - PETROL CAP, SWITCH BLANKS CALL OR TEXT 07730260999 FOR PRICES. LINK TO EBAY - http://cgi.ebay.co.uk/330581549966?ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2Fi.html%3F_from%3DR40%26_trksid%3Dp4712.m570.l1313%26_nkw%3D330581549966%26_sacat%3DSee-All-Categories%26_fvi%3D1&_rdc=1 Link to comment Share on other sites More sharing options...
Guest joey Posted June 26, 2011 Share Posted June 26, 2011 http://s1206.photobucket.com/albums/bb452/unionmotorsport/ THAT LINK IS TO THE ALBUM THAT THE PICS OF THE CIVIC ARE IN Link to comment Share on other sites More sharing options...
Guest joey Posted June 26, 2011 Share Posted June 26, 2011 Intercooler & pipes have now been sold Link to comment Share on other sites More sharing options...
