Guest straysupra96 Posted June 25, 2011 Share Posted June 25, 2011 Is it alright to stick dot 4 brake fluid in my 1996 mkiv TT supra (automatic) ? thanks lot. DAVE Quote Link to comment Share on other sites More sharing options...
Josh Posted June 25, 2011 Share Posted June 25, 2011 Have a look at the FAQ section, it'll tell you all you need to know. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 25, 2011 Share Posted June 25, 2011 As said go to 'FAQ Section', click on 'Search Forum' on top right hand side and do a search for 'fluids' Quote Link to comment Share on other sites More sharing options...
Dnk Posted June 25, 2011 Share Posted June 25, 2011 If i were you i'd do a fluid change, if you use a vaccum bleeder its easy to do and well worth it. I use Motul RBF600 and have found it to be pretty good for the money, even survives track days Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 25, 2011 Share Posted June 25, 2011 Is it alright to stick dot 4 brake fluid in my 1996 mkiv TT supra (automatic) ? thanks lot. DAVE Perfectly all right, so is DOT3, and DOT5.1 DOT5 is a most definite no though!!!! Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 25, 2011 Share Posted June 25, 2011 I recently re bled all mine with DOT 5.1 and they feel great. Quote Link to comment Share on other sites More sharing options...
Rookey Posted June 27, 2011 Share Posted June 27, 2011 Wouldn't 5.1 wreck the standard lines though? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted June 27, 2011 Share Posted June 27, 2011 3, 4 and 5.1 are inter mixable and won't so any harm to anything DOT5 however is a silicone fluid and will not mix with other fluids, it goes to jelly. Quite who gave two totally unmixable and different fluids, as important and oft used as BRAKE fluid, a difference in name of .1 I hate to think. Crazy. Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted June 27, 2011 Share Posted June 27, 2011 Wouldn't 5.1 wreck the standard lines though? I have uprated lines anywho Quote Link to comment Share on other sites More sharing options...
bodilx6 Posted June 28, 2011 Share Posted June 28, 2011 Go for temperature more than DOT type (except the DOT5 as chris says). I bought some DOT4 at some point, which ended up in immidiate brake fade after 3 times on the brake on a track. I have good experience with a dry boiling point of 270c + Quote Link to comment Share on other sites More sharing options...
