Bryson Posted June 24, 2011 Share Posted June 24, 2011 My Supra has got an HKS Boost controller installed and I don't have any instructions on how to use it and wondering if anyone can shed some light on how it works??? http://www.eliteautotint.co.uk/supratt/IMG_2049.JPG i also have an Apexi Rev speed meter and wonder what it can actually be used for? http://www.eliteautotint.co.uk/supratt/IMG_2047.JPG Sorry if these sound like stupid questions... Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted June 24, 2011 Share Posted June 24, 2011 Hi, have you Googled it? I found instructions for my boost controller online. Quote Link to comment Share on other sites More sharing options...
Bryson Posted June 24, 2011 Author Share Posted June 24, 2011 tried to google it but cant find anytihng Quote Link to comment Share on other sites More sharing options...
dwayne Posted June 24, 2011 Share Posted June 24, 2011 google "hks evc intsructions" Quote Link to comment Share on other sites More sharing options...
Scott Posted June 24, 2011 Share Posted June 24, 2011 tried to google it but cant find anytihng Your google must be broken, took me about 3 seconds http://www.plymouthlaser.com/hksevc/evc-4.doc Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted June 25, 2011 Share Posted June 25, 2011 (edited) http://www.mygen.com/users/dbruce/myz31/hks_evc_iv_boost_controller_install.htm I found this one in about 20 seconds.......................... Taken from Apexi Website re the other device. May not be identical as this is for a newer version but probably about right. The Rev/Speed meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM and elapsed times. Standard features include: Engine RPM, Vehicle Speed, Travel Distance and battery voltage ( all which can be displayed in real-time graph mode, or analogue mode; 1-4 channels at a time). Peak Hold, Replay (60secs) Speed limiter cut, 0-100m/200m/400m time with trap Speed. 0-100km/200km/H/300km/h times. Mid Range Acceleration ( user can preset any range of speed to measure), Stop watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM & Speed Outputs (for external devises requiring an RPM or Speed signal). Tire size correction ( for timing accuracy), and Vehicle weight input. Edited June 25, 2011 by sideexitsupra (see edit history) Quote Link to comment Share on other sites More sharing options...
Scott Posted June 25, 2011 Share Posted June 25, 2011 http://www.mygen.com/users/dbruce/myz31/hks_evc_iv_boost_controller_install.htm I found this one in about 20 seconds.......................... Taken from Apexi Website re the other device. May not be identical as this is for a newer version but probably about right. The Rev/Speed meter GP is a complete multi function measuring device designed to measure and monitor data such as vehicle speed, engine RPM and elapsed times. Standard features include: Engine RPM, Vehicle Speed, Travel Distance and battery voltage ( all which can be displayed in real-time graph mode, or analogue mode; 1-4 channels at a time). Peak Hold, Replay (60secs) Speed limiter cut, 0-100m/200m/400m time with trap Speed. 0-100km/200km/H/300km/h times. Mid Range Acceleration ( user can preset any range of speed to measure), Stop watch functions, Best Time Memory, RPM Warning, Speed Warning, RPM & Speed Outputs (for external devises requiring an RPM or Speed signal). Tire size correction ( for timing accuracy), and Vehicle weight input. Do you have me on ignore? If not check out the post before yours Quote Link to comment Share on other sites More sharing options...
