Suprab1 Posted June 23, 2011 Share Posted June 23, 2011 Ah i have a fly in my headlight. Any ideas how i can get him out? I'm going to try sucking him out with the hoover threw the main beam bulb hole but don't know if this will work. I would prefer not to pull my lights apart. Any ideas? Quote Link to comment Share on other sites More sharing options...
Josh Posted June 23, 2011 Share Posted June 23, 2011 A living one? Turn the headlights on and cook it! Quote Link to comment Share on other sites More sharing options...
dwayne Posted June 23, 2011 Share Posted June 23, 2011 attach a smaller flexible pipe to the end of the vacuum so you can feed into the bulb hole Quote Link to comment Share on other sites More sharing options...
Iky Posted June 23, 2011 Share Posted June 23, 2011 Ha ha, that's funny! Sorry to laugh at your misfortune but I couldn't help myself. Sound to me you have the best idea using the hoover. If that fails then a rod or something with loads of tape wrapped around it with the sticky side exposed ( i used this method to remove a stray bulb from my indicator) Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 23, 2011 Author Share Posted June 23, 2011 A living one? Turn the headlights on and cook it! Na he's on his back lol. attach a smaller flexible pipe to the end of the vacuum so you can feed into the bulb hole I was thinking this, if i could even suck him onto a pipe just to pull him out. The thin is the car has been sitting for a few weeks now so what was he doing in my light & how did he even get in. What a little nuisance they are. Quote Link to comment Share on other sites More sharing options...
Suprab1 Posted June 23, 2011 Author Share Posted June 23, 2011 Ha ha, that's funny! Sorry to laugh at your misfortune but I couldn't help myself. Sound to me you have the best idea using the hoover. If that fails then a rod or something with loads of tape wrapped around it with the sticky side exposed ( i used this method to remove a stray bulb from my indicator) I did laugh myself when i seen it. What a little tube going in my light, i tell you he's lucky he's dead because i would have to inflict pain on him on him for the annoyance he has caused lol. I like your idea though & will give it a bash, thanks. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted June 23, 2011 Share Posted June 23, 2011 Lol, I'd rather have a fly then a rat...... Quote Link to comment Share on other sites More sharing options...
Scott Posted June 23, 2011 Share Posted June 23, 2011 Lol, I'd rather have a fly then a rat...... A fly then a rat? Whatever next. Quote Link to comment Share on other sites More sharing options...
marcAB10 Posted June 23, 2011 Share Posted June 23, 2011 Its only 3 bolts and the headlight is removed, then just shake it out upside-down is the way I'd do it. Quote Link to comment Share on other sites More sharing options...
Scott Posted June 24, 2011 Share Posted June 24, 2011 Its only 3 bolts and the headlight is removed, then just shake it out upside-down is the way I'd do it. Who fitted your lights?? It's 1 bolt and 2 nuts I'll have you know /pedantic Quote Link to comment Share on other sites More sharing options...
cje001 Posted June 24, 2011 Share Posted June 24, 2011 Who fitted your lights?? It's 1 bolt and 2 nuts I'll have you know /pedantic Im sure there are three, but mine only had two on! Quote Link to comment Share on other sites More sharing options...
jim Posted June 24, 2011 Share Posted June 24, 2011 Tie a bit of rope round a spider's waist and lower him in through the hole at the back Rab. If the spider gets stuck then you're going to need a bird, and maybe a cat, dog, goat and horse. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 24, 2011 Share Posted June 24, 2011 put a venus fly trap under your bonnet Quote Link to comment Share on other sites More sharing options...
tbourner Posted June 24, 2011 Share Posted June 24, 2011 Put a spider in through the bulb hole and wait. Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 24, 2011 Share Posted June 24, 2011 lay a turd in the bay behind the light, flies love that Quote Link to comment Share on other sites More sharing options...
Iky Posted June 24, 2011 Share Posted June 24, 2011 lay a turd in the bay behind the light, flies love that Or a smelly trout. Quote Link to comment Share on other sites More sharing options...
Missile Posted June 24, 2011 Share Posted June 24, 2011 Put a spider in through the bulb hole and wait. I like your thinking, but would this not lead to a post.... Spider stuck in my headlight. Quote Link to comment Share on other sites More sharing options...
SupraP-Z Posted June 24, 2011 Share Posted June 24, 2011 A fly then a rat? Whatever next. LMAO...good spot. Id go with the hoover and then if that doesnt work, go for the sticky tape idea Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 24, 2011 Share Posted June 24, 2011 chopsticks or needle on cotton, throw it in and spear the fly, then real it out Quote Link to comment Share on other sites More sharing options...
tbourner Posted June 24, 2011 Share Posted June 24, 2011 I like your thinking, but would this not lead to a post.... Spider stuck in my headlight. Simple, then you just find some kind of bird that will set up a nest and eat the spider. Quote Link to comment Share on other sites More sharing options...
Missile Posted June 24, 2011 Share Posted June 24, 2011 Simple, then you just find some kind of bird that will set up a nest and eat the spider. And if Said bird were to get stuck....a cat maybe Quote Link to comment Share on other sites More sharing options...
tbourner Posted June 24, 2011 Share Posted June 24, 2011 And if Said bird were to get stuck....a cat maybe I think the cat would be the final installation, as it would stick its paw in to catch the bird then run off (after chasing it around the engine bay for half an hour and not killing the damn thing). Quote Link to comment Share on other sites More sharing options...
jackso11 Posted June 24, 2011 Share Posted June 24, 2011 It will be fast if you de-cat it Quote Link to comment Share on other sites More sharing options...
d-_-b Posted June 24, 2011 Share Posted June 24, 2011 Get a metal coat hanger / peice of thick wire, wrap the end in tape so you have a "teardrop type shape, then double the tape round on itself so the end is sticky (take a bit of the "tack" off of it by touching it a few times - this wa it wont properly attach itself to the inside of the lens if it touches) then carefully navigate the wire (via the main bulb hole) to where the fly is, stick it and slowly manouver out. Job done : ) Quote Link to comment Share on other sites More sharing options...
Iky Posted June 24, 2011 Share Posted June 24, 2011 b;3149524']Get a metal coat hanger / peice of thick wire, wrap the end in tape so you have a "teardrop type shape, then double the tape round on itself so the end is sticky (take a bit of the "tack" off of it by touching it a few times - this wa it wont properly attach itself to the inside of the lens if it touches) then carefully navigate the wire (via the main bulb hole) to where the fly is, stick it and slowly manouver out. Job done : ) Hey! that was my idea! Quote Link to comment Share on other sites More sharing options...
