Aftermarket injector wiring.
hodge
Hmmm. Injectors work using a electromagnetic coil. Unless I'm mistaken in how these things work (which I might be), if you wire it up the wrong way round it'll just try to shut even more by pushing the pintle the wrong direction.
By "worked either way" do you mean it delivered the same amount of fuel? Or it still made a "click" noise? :)
Considering how easy it is to wire it up the same way as OEM, I can't see any reason why you wouldn't.
What I don't get, if polarity isn't important, is how the injector pintle knows which way to go when the solenoid is energised? I've been googling it but nothing I've found has said one way or the other yet.
(I'm on nightshift, can you tell :) )
It doesn't matter but I always make sure I get them all the same, it's obvious which way they are on the loom but some of the injector fly leads have 2 black wires.
I look at the stock injector and go by that.
It would only matter if the solenoid was pulling a magnetized plunger. The plunger has no magnetic polarity save anything it gains latently. Bosch mark their injectors with + and - as some high end ecus do use the back emf to do something with. The Zytek ecu on my Mugen V8 race engine uses this, they call it recirculation. I do have an SAE paper written about this somewhere, but I can't find it. From memory it helps them close faster.
