Aftermarket injector wiring.
hodge
Hmmm. Injectors work using a electromagnetic coil. Unless I'm mistaken in how these things work (which I might be), if you wire it up the wrong way round it'll just try to shut even more by pushing the pintle the wrong direction.
What I don't get, if polarity isn't important, is how the injector pintle knows which way to go when the solenoid is energised? I've been googling it but nothing I've found has said one way or the other yet.
(I'm on nightshift, can you tell :) )
It would only matter if the solenoid was pulling a magnetized plunger. The plunger has no magnetic polarity save anything it gains latently. Bosch mark their injectors with + and - as some high end ecus do use the back emf to do something with. The Zytek ecu on my Mugen V8 race engine uses this, they call it recirculation. I do have an SAE paper written about this somewhere, but I can't find it. From memory it helps them close faster.
