MY New bonnet
Rob_Mitchell
cheers for the pics mate thats gave me a better idea and similar to what i was thinking, been a great help though.
yeah cheers guys i dont think its as rare as i think but just bloody exspensive for what it is, great fit though but poo skinny brackets... ill get it painted soon but put stock on for now.
I like it! least you finally found the bonnet youve been after im still hunting for a veilside
yeah never give up mate. look how long it took for a greddy oil cap!! i should have had the do-luck spoiler off jamie when i had been offered it and also i hear someone has the exhaust ^^^^^ lmao ill have him
Lol i have a Do-Luck Radiator and rear Do-Luck Brace too muhahahaha.
Nice looking bonnet Rob. Got more shots of your tension set? By the way, saw you interested in top feed injectors other day, you got a GTE floating about somewhere or something ;)
need 650 or 800 drop in injectors for my build mate. not sure on the pics ill have a look for you
1st off i would rip the mounting bolts out as they are only held in with resin,and not very well at that,
you dont need to split the bonnet open,that was how daves arrived to me and just had that pic of t bolts.a pair of pliers will twist them out no probs
then make 2 plates and weld a pair of nuts to them.measure the nut spacing on your stock bonnet.
slot these in through the bonnet hock holes next to the mounts and counter sink poppet rivet the plates between the to skins of the bonnet.
this way the bonnet will be sandwiched between the hinge and the plate,far stronger than the effort do luck do.
then do the same for the safety catch,this can be slotted in through the catchs,use a piece of wire to giude it in
again the safety catch is then secure rather than held in with self tapers as was the last one i sorted.
next the catchs them selfs are to thin so when you shut the bonnet it will rattle up n down thus letting air get under it,and thats when it all goes horribly wrong when at speed.i had some tube the same outside diameter as the stock bonnet catchs.cut in half and weld to the catchs.
if you zoom in on this pick you will see what i did,sorry only picture i could find of this
Edited by baldy (see edit history)
