Guest v8_project Posted June 22, 2011 Share Posted June 22, 2011 Hi all, I have put this on ebay now, I have a W58 complete conversion kit for a Soarer GZ20 (old shape not the JZZ30). However with the use of a bell housing from a manual IS300 (2JZ type, toyota part number 31111‑53010) you could marry this gearbox up to a 1JZ or 2JZ supra. The prop, flywheel,starter motor and pedals would have to be modified I guess. It includes: W58 gearbox 65k miles clutch master cylinder clutch pedal clutch slave cylinder flywheel bell housing for the 1G-GTE front part of prop clutch starter motor Its now on ebay here, but open to offers http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260805456822 Link to comment Share on other sites More sharing options...
supra steveo Posted June 22, 2011 Share Posted June 22, 2011 that looks like a mkIII slave cylinder are the mkIII and mkIV interchangeable ? Link to comment Share on other sites More sharing options...
Guest v8_project Posted June 22, 2011 Share Posted June 22, 2011 Its a W58 slave cylinder, and some of the MK3 came with W58, so yes in a way. If you fit the W58 to the mk4 supra with the IS300 bell housing (2JZ version) then the slave would sit on the transmission fine. Link to comment Share on other sites More sharing options...
