k9l3 Posted June 22, 2011 Share Posted June 22, 2011 hi I need help the garage where I getting a full service for my car said I will need for the spark plugs . new wire looms for the coils soon. is there a word I looking for to make it easy to find part . thanks Quote Link to comment Share on other sites More sharing options...
Nic Posted June 22, 2011 Share Posted June 22, 2011 A search of the FAQ section or rest of the forum should find everything you need FAQ Spark Plugs Broken coil pack connectors is probably what the garage is referring to, no need to replace the complete loom (they are very expensive) just need to fit new connectors. How To refurbish Coil Pack Connectors FAQ - Fluids Service Manual Quote Link to comment Share on other sites More sharing options...
k9l3 Posted June 22, 2011 Author Share Posted June 22, 2011 A search of the FAQ section or rest of the forum should find everything you need FAQ Spark Plugs Broken coil pack connectors is probably what the garage is referring to, no need to replace the complete loom (they are very expensive) just need to fit new connectors. How To refurbish Coil Pack Connectors FAQ - Fluids Service Manual thanks mate all he said is that they had to be Careful putting the the leads back on and that it could start miss firing. so will need replacing soon . he explained its the wirring loom for the coils. Quote Link to comment Share on other sites More sharing options...
Nic Posted June 22, 2011 Share Posted June 22, 2011 thanks mate all he said is that they had to be Careful putting the the leads back on and that it could start miss firing. so will need replacing soon . he explained its the wirring loom for the coils. It will be the coil pack connectors (plastic plugs) on the end of the wiring loom that connect to the coils. It's a very common problem, over time the heat of the engine makes the plastic connectors very brittle, crack and disintegrate, the broken connectors can then lead to misfire problems. No need to replace the complete loom, you can just buy new connectors from Toyota and replace the broken ones, see the link I posted earlier explaining the process and the parts needed. Quote Link to comment Share on other sites More sharing options...
k9l3 Posted June 22, 2011 Author Share Posted June 22, 2011 It will be the coil pack connectors (plastic plugs) on the end of the wiring loom that connect to the coils. It's a very common problem, over time the heat of the engine makes the plastic connectors very brittle, crack and disintegrate, the broken connectors can then lead to misfire problems. No need to replace the complete loom, you can just buy new connectors from Toyota and replace the broken ones, see the link I posted earlier explaining the process and the parts needed. thank you very much. Quote Link to comment Share on other sites More sharing options...
k9l3 Posted July 9, 2011 Author Share Posted July 9, 2011 It will be the coil pack connectors (plastic plugs) on the end of the wiring loom that connect to the coils. It's a very common problem, over time the heat of the engine makes the plastic connectors very brittle, crack and disintegrate, the broken connectors can then lead to misfire problems. No need to replace the complete loom, you can just buy new connectors from Toyota and replace the broken ones, see the link I posted earlier explaining the process and the parts needed. Hi i received these which cost me 46 pound is this the right part and all i need? http://img810.imageshack.us/img810/5403/photo0144j.jpg http://img24.imageshack.us/img24/7447/photo0143ub.jpg Quote Link to comment Share on other sites More sharing options...
imi Posted July 9, 2011 Share Posted July 9, 2011 no, those connect to the bottom of the coil packs themselves and slot over the spark plugs. what you need are coil pack CONNECTORs, plastic plugs with two terminals the hang off the end of the wiring loom. These them plug into the coil pack and provide them with current. Search on here as you will find the exact part number that you need. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 9, 2011 Share Posted July 9, 2011 Hi i received these which cost me 46 pound is this the right part and all i need? http://img810.imageshack.us/img810/5403/photo0144j.jpg http://img24.imageshack.us/img24/7447/photo0143ub.jpg I would advise taking them back mate. Absolutely useless..... and £46 They seen you coming Quote Link to comment Share on other sites More sharing options...
GINNO78 Posted July 9, 2011 Share Posted July 9, 2011 You want these >>>> Toyota 90980-11246 Quote Link to comment Share on other sites More sharing options...
k9l3 Posted July 9, 2011 Author Share Posted July 9, 2011 thanks I thought this was not right.. Quote Link to comment Share on other sites More sharing options...
k9l3 Posted July 9, 2011 Author Share Posted July 9, 2011 You want these >>>> Toyota 90980-11246 is this right under toyota system catalogue the part number comes under condenser? Quote Link to comment Share on other sites More sharing options...
bignum Posted July 9, 2011 Share Posted July 9, 2011 http://whifbitzperformancetuning.co.uk/toyota-supra-supra-ignition-parts-toyota-p-1552.html Quote Link to comment Share on other sites More sharing options...
k9l3 Posted July 11, 2011 Author Share Posted July 11, 2011 http://whifbitzperformancetuning.co.uk/toyota-supra-supra-ignition-parts-toyota-p-1552.html hi mate on the whifbits site does the clips / connectors come with everything to directly change them or do you have to do anything to it ie change pins over etc Quote Link to comment Share on other sites More sharing options...
k9l3 Posted July 11, 2011 Author Share Posted July 11, 2011 I would advise taking them back mate. Absolutely useless..... and £46 They seen you coming i am bloody stupid i asked for connectors not rubber caps but they being fair and going to refund me Quote Link to comment Share on other sites More sharing options...
