Guest tony1979 Posted June 20, 2011 Share Posted June 20, 2011 The headlights seam to be quite smoky or misted up, and not clear at all, is there any way of removing this or is it time for a new set of headlights. Quote Link to comment Share on other sites More sharing options...
Bryson Posted June 20, 2011 Share Posted June 20, 2011 Try covering the headlights with sheets of newspaper then put full beam lights on. The headlight unit should start to warm up inside and this should then start to clear any build up of water etc. Worked with my uk headlights Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted June 20, 2011 Share Posted June 20, 2011 Origiinal t cut, works a treat, scrub hard though Quote Link to comment Share on other sites More sharing options...
Nic Posted June 21, 2011 Share Posted June 21, 2011 http://www.mkivsupra.net/vbb/showthread.php?153261-Refurb-and-painting-headlights-guide&highlight=headlights Quote Link to comment Share on other sites More sharing options...
Shane Posted June 21, 2011 Share Posted June 21, 2011 Homer posted a thread a week ago or so about this. He used G3 cutting compound which I have since tried and makes easy work of it. Available at Halfruads at a tenner a tube. Much less effort than T-cut imo. Intrestingly, I couldnt see it when I got there and asked o one of the staff who went away and said it was a web only item. On my way out I found a huge display at the end of one of the isles full of G3 Products including the "web only" item. They are so hopeless there, and to make it worse my Son works at that branch as the Bike Hut specialist! Quote Link to comment Share on other sites More sharing options...
