quick question about EGV actuator
Guest George89
Guest George89
If the actuator above the 2nd turbo is stuck open will that stop the 2nd turbo from kicking in? and make me loose boost completly at 4.5K rpm when the 2nd turbo should kick in?
As i produce 0.4 bar of boost and then all goes when the 2nd turbo is ment to kick in. But 1st turbo doesn't boost like it should it takes 3rd gear to get it to 0.4 bar
