Intermittant second turbo
markssupra
Hi all,
Still having boost problems, seems to be an intermittant fault as sometimes second turbo is working and boosting upto 1.2 bar, other times only first turbo boosting to around 0.7-0.8.
I am running a Profec B spec II EBC and while watching the vaccum/ boost display before I had problems it would vary very slighty while cruising. Now it seems to stick on 0.0 bar for longer unless I lift off completely (-0.75 bar) or accelerate.
I think the IACV vsv is not working correctly or the EGBV vsv.
Could the small inline filter to the Boost controller cause this?
Any advice would be helpful or if someone has some working VSV's I could use to eliminate problems.
Thanks
